Kay-Uwe Kasemir wrote:
Hi:
Do I understand correctly that the most likely impact for EPICS might
be this type of code:
struct xyz_regs
Word control;
Word status;
void xyz_operate(char *vme_base)
struct xyz_regs *xyz = (struct xyz_regs *) vme_base;
xyz->control = 0x1234;
if (xyz->status & 0x8000)
The mapping of C structures to hardware registers?
volatile should be used for all access to hardware registers.
volatile prevents compiler optimization.
In that case, the compiler optimization of aliased pointers
isn't the only problem. There's also the structure padding,
memory alignment, and byte order that causes portability issues.
Isn't that best handled by performing register access
via routines like the vxWorks sysInByte(), sysInWord(), sysInLong(),
sysPciInLong(), ... ?
-Kay
- Re: C strict aliasing rules Eric Norum
- C strict aliasing rules Eric Norum
- Re: C strict aliasing rules Benjamin Franksen
- Re: C strict aliasing rules Kay-Uwe Kasemir
<2006>
<2006>
