On Nov 27, 2006, at 12:23 PM, Andrew Johnson wrote:
Eric Norum wrote:
static inline void
writethree(int *p)
short *palias = (short *)p;
*palias = 3;
int
testalias()
int value = 12345678;
writethree(&value);
return value;
One might expect that the value returned from testalias() would
be 12345678 with either its most-significant 16 bits or least-
significant 16 bits set to 3 (on most architectures).
One would be wrong, though.
I don't think life is quite as bad as it might seem; if you take
off the "static inline" keywords from writethree(), I suspect the
optimizer may not be able to be quite as aggressive in throwing out
code - please experiment and respond to that suggestion.
In that case the optimizer does not remove the function, but it does
remove the call to it and its effect from testalias:
norume@gnarly 679> cat a.c
void
writethree(int *p)
*palias = 3;
int
testalias()
writethree(&value);
return value;
norume@gnarly 680> m68k-rtems4.7-gcc -O4 -Wall -S a.c
norume@gnarly 681> cat a.s
#NO_APP
.file "a.c"
.text
.align 2
.globl writethree
.type writethree, @function
writethree:
link.w %fp,#0
move.l 8(%fp),%a0
move.w #3,(%a0)
unlk %fp
rts
.size writethree, .-writethree
.align 2
.globl testalias
.type testalias, @function
testalias:
link.w %fp,#-4
move.l #12345678,%d0
unlk %fp
rts
.size testalias, .-testalias
.ident "GCC: (GNU) 4.1.1"
The writethree function doesn't even have to come first. The
optimizer appears to work on the file after it's all been consumed:
norume@gnarly 686> cat a.c
int
testalias()
writethree(&value);
return value;
void
writethree(int *p)
*palias = 3;
norume@gnarly 687> !m6
a.c: In function 'testalias':
a.c:5: warning: implicit declaration of function 'writethree'
a.c: At top level:
a.c:10: warning: conflicting types for 'writethree'
a.c:5: warning: previous implicit declaration of 'writethree' was here
norume@gnarly 688> !ca
cat a.c
int
testalias()
writethree(&value);
return value;
void
writethree(int *p)
*palias = 3;
Since we don't (shouldn't?) have any C routines in base that are
marked as "static inline", I don't think our problems are as large
as you make out them to be. I suspect the rules for C++ are subtly
different, so it would also be interesting to see what using the C+
+ compiler generates.
I'm afraid that the above test shows that any code is a candidate for
removal by the optimizer. :-(
I think that we should give consideration to adding -fno-strict-
alaising to all gcc invocations and the equivalent to any other
compilers we can find.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: C strict aliasing rules Benjamin Franksen
- C strict aliasing rules Eric Norum
- Re: C strict aliasing rules Andrew Johnson
<2006>
<2006>
