Of course I'm not suggesting (and I should have made this clear - sorry)
that this is a fix. This is just data to show that making NULL correct
for this architecture fixes this single instance of the problem.
John
On Tue, 2006-10-31 at 15:26 -0600, Andrew Johnson wrote:
> >> Putting the following define in all .c source files (after the last
> >> #include)
> >> #define NULL 0L
> >> does indeed fix things.
> It may fix things on your 64-bit machine, but it won't everywhere --
> you're providing a long argument when the XtVaSetValues() routine is
> looking for a pointer; the two may still be different sizes on other
> machines.
> NULL is a strange beast. On my linux-x86 machine gcc 4.0.2 defines it
> as ((void *)0) whereas g++ 4.0.2 defines it as __null. The Solaris C
> C++ compiler defines it to be 0 in all circumstances; the C compiler
> uses 0L if we're compiling for LP64 archs, else 0.
> I think that the correct solution is to accept the compiler's definition
> and just use NULL. Thus if removing NULL from dbDefs.h solves this
> problem then that's the right solution for now and it'll be that way
> from R3.14.9 onwards.
> - Andrew
smime.p7s
Description: S/MIME cryptographic signature
- Re: Getting alh to run on AMD64 (linux 64-bit OS) Andrew Johnson
Re: Getting alh to run on AMD64 (linux 64-bit OS) Kay-Uwe Kasemir
<2006>
<2006>
