Putting the following define in all .c source files (after the last
#include)
#define NULL 0L
does indeed fix things.
It may fix things on your 64-bit machine, but it won't everywhere --
you're providing a long argument when the XtVaSetValues() routine is
looking for a pointer; the two may still be different sizes on other
machines.
NULL is a strange beast. On my linux-x86 machine gcc 4.0.2 defines it
as ((void *)0) whereas g++ 4.0.2 defines it as __null. The Solaris C
C++ compiler defines it to be 0 in all circumstances; the C compiler
uses 0L if we're compiling for LP64 archs, else 0.
I think that the correct solution is to accept the compiler's definition
and just use NULL. Thus if removing NULL from dbDefs.h solves this
problem then that's the right solution for now and it'll be that way
from R3.14.9 onwards.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- Re: Getting alh to run on AMD64 (linux 64-bit OS) John William Sinclair
- Re: Getting alh to run on AMD64 (linux 64-bit OS) Kay-Uwe Kasemir
Re: Getting alh to run on AMD64 (linux 64-bit OS) Andrew Johnson
<2006>
<2006>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
