Jeff Hill wrote:
I had a quick look at the JNI library and I also don’t see any obvious
solution that does not require modifications to EPICS base.
Perhaps the next question is whether the proposed interface registering
for thread begin / exit callbacks should be implemented in (A) the CA
client library or (B) alternatively in epicsThread (see epicsThread.h).
I worry that it’s only a matter of time until we have more requests to
tightly integrate the Java VM within processes that might be running
EPICS. Perhaps it’s not a bad idea to, only when the Java VM is embedded
in a process that is also running EPICS, go with (B) and always bind the
VM to each and every EPICS thread that gets started. Since this would
occur only when the thread starts and stops presumably the overhead
would be minimal.
Furthermore, if we implement the epicsThread start / exit hook interface
I can also see a low overhead option using thread private variables that:
O attaches to the VM from within the JNI callback only the first time
that a JNI callback gets called by EPICS for a particular thread
O in the global epicsThread exit hook un-registers the current thread
with the VM only if it is currently registered with the vm
I could provide a pseudo code implementation for the 2^nd option if you
are interested.
I am thinking that the proposed interface belongs in epicsThread.
What do you think?
Jeff
*Sent:* Wednesday, October 18, 2006 12:03 PM
*To:* Jeff Hill
*Cc:* Ernest L. Williams Jr.; Thomas Pelaia II; Matej Sekoranja;
Kasemir, Kay; [email protected]; Andrew Johnson
*Subject:* Re: bug report
On 10/17/06, Jeff Hill wrote:
Even if the memory leak is fixed by Sun, it would be desirable to fix
the JNI code so that it doesn't need to register/unregister the thread
(apparently a very high overhead call) from within every subscription
update callback? If there isn't a solution in the java support then
perhaps one possibility would be to provide a registration interface in
the ca client library specifying a user callback that gets run in the
context of a CA thread when it (the thread) starts and when it exists.
We might then register / unregister the thread with java from that call
back.
I agree that in principle, the right place to put this would be in the
epicsThread implementation. Looking at the current code we will have to
add the hook calls to each of the src/libCom/osi/os/*/osdThread.c files,
but we appear to have suitable wrapper functions in all 4
implementations that will allow us to do that.
I'd like to see a firm proposal for the API, including an indication of
what is expected to happen if a callback gets registered after several
threads have already been created. We should already have sufficient
infrastructure to be able to call a hook for each existing thread if we
decide that's what we want to happen, but that call would not be from
the context of the thread itself, so it might not be a useful thing to do.
I would want to allow more than one hook to be registered at the same
time, and for there to be both a C and C++ API for registering hooks.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
RE: Changes for RTEMS on ARM (at91rm9200ek) Jeff Hill
Timetable for R3.14.9? Andrew Johnson
<2006>
<2006>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
