The name length -- sizeof(pifreq->ifr_name) -- is 16, correct.
It seems that the network init code writes something strange into the
buffer so that the RTEMS version of the ifrec_size macro fetches junk
trying to look at pifreq->ifr_addr.sa_len and sees a 54 there (adding up
to 70).
Eric Norum wrote:
You need to figure out why ifreq_size is returning the wrong value.
The macro definition for RTEMS (src/libCom/osi/os/RTEMS/osdSock.h) is:
#define ifreq_size(pifreq) (pifreq->ifr_addr.sa_len +
sizeof(pifreq->ifr_name))
You could add some code to check, but I'm pretty sure that
the sizeof(pifreq->ifr_name) is 16. So you need to figure out why
the pifreq->ifr_addr.sa_len is unreasonable. Check the network
driver initialization code and see if it's doing something odd.
On Aug 23, 2006, at 9:05 AM, Ralph Lange wrote:
Hm...
Ralf added some code to osiSockDiscoverBroadcastAddresses() that
memcpy-copies the odd-length ifreq into a word-aligned buffer, then
uses a pointer to this aligned copy to hand to the subsequent calls.
Effect: The RTEMS board boots, doesn't crash, and finds four
interfaces (lo: and eth0: both appear twice), two of which it
recognizes as AF_INET. External CA clients can connect, but get junk
in the monitor updates (time stamp and data are garbled).
I'm not sure what exactly you did here. Did you modify ifreqNext to
always use sizeof (*pifreq) as the offset to the next address entry?
I can't see how you could step through the addresses otherwise.
There's an additional local buffer, word-aligned. After stepping through
the array using ifreqNext, we're memcpy'ing from pifreq to our buffer,
using the same algorithm as ifreqNext to determine the number of bytes
to copy. That way we're creating an additional local copy of the ifreq
entry with the only difference of the pointer to it always being
word-aligned.
So it seems that the returned ifreq length of 70 for the first
interface really is the reason for crashing on the second entry which
is not aligned.
Yes, likely because the 70 is ridiculous and you end up looking at
some random memory contents for the second entry.
Well - we are identifying all network interfaces on the ARM board using
the original ifreqNext and our word-aligned copies. All the names are
there. So I guess it can't be really random memory. Is 70 really that
ridiculous? I mean, it does sound so, but why are we finding all
interfaces using that big step of 70 after the first ifreq entry?
Would you see the additional buffer as an adequate way to handle
this? (Probably not...)
If not, where in the BSD network code would we have to add the padding?
I don't think that this is an issue of padding. It's an issue of a
bad sa_len getting in there somewhere.
If you have the ability to put in watchpoints it would be useful to
see each time that memory location was written to.
Yes. No watchpoints, though. Ralf is trying to figure out looking at the
code who is filling the buffer with what, why, when, and where. Not a
trivial task.
Thanks for your help, which is greatly appreciated!
Ralph & Ralf
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
- RE: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Jeff Hill
- Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
<2006>
<2006>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
