2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned?
To: Eric Norum <[email protected]>
Cc: Jeff Hill <[email protected]>, EPICS Core Talk <[email protected]>, Ralf Hartmann <[email protected]>
Date: Tue, 22 Aug 2006 18:26:57 +0200
Nah. Sorry. Darn.
calloc() is working - our assert had the big bug right in the expression :-)
You were obviously much closer -
Doing the printout in ifreqNext() that you suggested, we find the size of the first structure coming up is 70 (dec), which is not divisible by 4, which leads to the pointer to the second structure being misaligned.
Who decides the size of the ifreq structure and doesn't pad correctly? Or should we do the padding up there?
Ralph & Ralf
Eric Norum wrote:
That sounds like a pretty big bug in the newlib library or the underlying RTEMS memory allocator!
Or heap-space corruption.......
On Aug 22, 2006, at 10:55 AM, Ralph Lange wrote:
We're now at a point where we can see that the calloc() that creates the array returns an odd pointer. Are we right that this is a faulty implementation of calloc()? (Which is supposed to "return a pointer aligned to suit any type of variable"?)
Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Ralph Lange
Prev: Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
Next: Re: osiSockDiscoverBroadcastAddresses(): pointer not word-aligned? Eric Norum
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
