Hi Andrei,
Liyu, Andrei wrote:
Could you, please, explain better about local CA client?
How can it subscribe to local records automatically? Or will it have
list?
It can use the dbStaticLib routines to find out all of the record
instances that are loaded on the IOC, and set a CA monitor on each one -
see the example code at the end of the Static Database Access chapter of
the IOC Application Developers Guide for a starting point on doing the
dbStaticLib part.
How standard CA client will send to log server? Or it is special CA
application?
It is a CA client application that is run on each IOC, which knows how
to send alarm details to the log server.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- RE: alarm hook Liyu, Andrei
<2006>
<2006>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
