g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Subject: Re: alarm hook
To: Matthias Clausen <Matthias.Clausen@desy.de>, Geoff Savage <savage@fnal.gov>, EPICS core-talk <core-talk@aps.anl.gov>
Date: Mon, 19 Jun 2006 10:36:15 -0500
Hi Matthias,
Matthias Clausen wrote:
in preparation for my meeting with Geoff at Fermilab I wand to send you the proposed hook into base which Bernd Schoeneburg and Bob already 'somehow' agreed on:
Here's Berns mail to Bob:
recGblResetAlarms is called in monitor() which is called in the end of record processing just before recGblFwdLink and after recGblGetTimeStamp. After calling recGblResetAlarms in monitor() the value changes are checked (not interesting for us). recGblResetAlarms checks for alarm changes and returns the fist approach of the monitor mask, which is later used for postEvents. postEvents can be called from anywhere like device support, snl, subroutines, 'homebrew' records etc. I think recGblResetAlarms is called in the monitor function of records only. So I think it is the perfect place. Please check it and correct me if I am wrong.
The code could look like this (the end of recGblResetAlarms):
    if(sevr!=nsev || stat!=nsta) {
++:    logAlarm (pdbc, sevr, stat);
++:    /* nsev and nsta are in pdbc->sevr and pdbc->stat */
        ackt = pdbc->ackt; acks = pdbc->acks;
        if(!ackt || nsev>=acks){
            pdbc->acks=nsev;
            db_post_events(pdbc,&pdbc->acks,DBE_VALUE);
    return(mask);
My question:
Do you also agree with approach?
I agree with the location and arguments of the call, which I believe are the same as Fermilab have been using.
And - what would be implemented in base for logAlarm ()?
This could be an empty function which just returns - or it could be the 'real' thing where you'll have to check whether alarm logging should be used at all. The empty function could be replaced/ overloaded by the 'real' function if you want to use putAlarm.
I think we just need a global pointer for the routine which will be called if it's not NULL, so your code just sets it to hook in. Here's my proposed patch:
Index: recGbl.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/recGbl.h,v
retrieving revision 1.9
diff -u -b -r1.9 recGbl.h
--- recGbl.h    12 Feb 2003 21:22:23 -0000      1.9
+++ recGbl.h    19 Jun 2006 15:25:16 -0000
@@ -30,13 +30,23 @@
      : FALSE\
+/* Structures needed for args */
-/* Global Record Support Routines*/
 struct link;
 struct dbAddr;
 struct dbr_alDouble;
 struct dbr_ctrlDouble;
 struct dbr_grDouble;
+struct dbCommon;
+/* Hook Routine */
+typedef void (*RECGBL_ALARM_HOOK_ROUTINE)(struct dbCommon *prec,
+    unsigned short sevr, unsigned short stat);
+extern RECGBL_ALARM_HOOK_ROUTINE recGblAlarmHook;
+/* Global Record Support Routines */
 epicsShareFunc void epicsShareAPI recGblDbaddrError(
     long status, struct dbAddr *paddr, char *pcaller_name);
 epicsShareFunc void epicsShareAPI recGblRecordError(
Index: recGbl.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/recGbl.c,v
retrieving revision 1.60.2.2
diff -u -b -r1.60.2.2 recGbl.c
--- recGbl.c    4 Nov 2004 19:21:08 -0000       1.60.2.2
+++ recGbl.c    19 Jun 2006 15:25:16 -0000
@@ -42,6 +42,10 @@
 #include "recGbl.h"
+/* Hook Routines */
+RECGBL_ALARM_HOOK_ROUTINE recGblAlarmHook = NULL;
 /* local routines */
 static void getMaxRangeValues();
@@ -239,6 +243,7 @@
     if(stat_mask)
         db_post_events(pdbc,&pdbc->stat,stat_mask);
+       if (recGblAlarmHook) (*recGblAlarmHook)(pdbc, sevr, stat);
            pdbc->acks=nsev;
If there is general agreement between DESY and FNAL about this, I'll commit the change which will then appear in R3-14-9.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
Re: alarm hook Matthias Clausen
Prev: Re: External source code repository Andrew Johnson
Next: RE: alarm hook Liyu, Andrei
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013
Prev: RE: External source code repository Liyu, Andrei
Next: Re: alarm hook Matthias Clausen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
