Kay-Uwe Kasemir wrote:
The out-of-memory argument might be artificial.
I see these realistic cases:
1) A memory allocation fails because by accident you've tried to
allocate 5GB.
In that case you do have 1k left to allocate a nice looking string.
Agreed.
2) You're fully out of mem, not even 100 bytes left for the error message
-> you're really stuck and I doubt any special string reader stuff
will help you out,
because you won't be able to print it, can't open a dialog box,
can't send it to a message logger, ...
You'll notice that you're out of mem, you don't need the exception
to tell you anyway.
This case is not always true, for at least two reasons.
1. If the routine responsible for catching the exception makes sure to
reserve space in the string for any error messages before it runs the
try block, then there will be no problem in doing the string conversion
from the exception object. If errlog implements the StringEditor API
then the string could be converted straight into the preallocated
network buffer, so no memory allocation is necessary to log the problem.
2. In the stack unwinding between the throw and the catch, there may be
objects being destroyed that release memory back to the system; this
means that by the time we get to the exception handler there may be
memory available that wasn't available at the point of the throw. As a
result if we have a choice, it is better to do memory allocation in the
exception handler than in the exception object's constructor.
I agree that in a client application doing complicated things like
opening dialog boxes isn't likely to be possible, but for the small
embedded IOC world we should try to make the system robust against
memory shortages. IIRC the current iocCore software is capable of
running with little or no free memory - it can't connect any new CA
clients or even execute shell commands, but most records are able to
carry on processing normally.
Yes, you can defer the string creation.
I don't think it buys much.
I'm more concerned about the robustness-in-the-face-of-memory-starvation
aspect than the efficiency - I fully accept that we shouldn't be using
exceptions for normal conditions due to their complexity and performance
characteristics.
I did like your idea of an exception class with a printf constructor
though...
- Andrew
There is no S in exprexxo.
- 3.15 C++ Exception classes Andrew Johnson
- Re: 3.15 C++ Exception classes Kay-Uwe Kasemir
- Re: 3.15 C++ Exception classes Andrew Johnson
RE: 3.15 C++ Exception classes Jeff Hill
<2006>
<2006>
