Benjamin Franksen wrote:
I am not convinced, neither by the argument above ("write a try/catch
phrase that could catch warnings but not errors or fatalities") nor by
the Jeff's design where the severity is a class member.
IMHO, exceptions should not be classified at all into severity types.
I agree with you; as I said in my penultimate sentence:
> I'm also not convinced that the thrower can determine the severity of
> an exception in practice.
I guess I didn't express all of the reasons for rejecting Jeff's
severity() method. My suggestion about being able to catch warnings was
not made because I want to do that, but to show that using the exception
class hierarchy makes more sense than hiding warning/error information
inside the exception object itself.
Instead, I would propose to create /one/ special exception type that
is reserved for 'assert' style failures, i.e. failures that can only
becaused by broken or corrupted code. IIRC, this is what a 'fatal'
severity normally means in Jeff's code.
I think this is very similar to Kay's point, which I will respond to
separately...
- Andrew
There is no S in exprexxo.
- Re: 3.15 C++ Exception classes Andrew Johnson
Fwd: 3.15 C++ Exception classes Kay-Uwe Kasemir
<2006>
<2006>
