Last September, Jeff Hill sent me this class definition, with the
suggestion that something like this be adopted as the basis for future
EPICS exception objects:
struct Diagnostic : exception {
public:
enum severity_t {
sevWarning, sevError, sevFatal };
virtual severity_t severity () const = 0;
virtual void context ( StringSegment & ) const = 0;
Having recently committed my StringReader and StringEditor interfaces
and some implementations to the 3.15 CVS tree for Jeff to use in
DataAccess, I am looking at designing a modified version of this class
for general use. The main point of this email is to document what I'm
currently implementing, but I guess that this may result in some
discussion from Jeff and others as well.
severity(): I don't like this; the severity information should be
implicit in the hierarchy of the class that is being thrown. I expect
to be able to write a try/catch phrase that could catch warnings but not
errors or fatalities; I don't want to catch everything and then have to
re-throw anything that's more severe than a warning. I'm also not
convinced that the thrower can determine the severity of an exception in
practice. Therefore I'm not going to include the severity part.
context(): I'm replacing Jeff's StringSegment with a StringEditor and
renaming this function to what(), since it performs the exact same role
as the std::exception::what() function, namely provides a way to convert
the exception data into a displayable string.
status(): We often provide wrappers to allow C code to call C++ code.
The C routines can't trap exceptions, so those C++ wrappers may have to
convert such exceptions into a long integer status value. The exception
object is the obvious thing to know what status value to return, so I'm
considering adding this method to provide that. If the conversion to
the single C status value would lose diagnostic data that is stored in
the exception object, this routine can log that information to the error
logger at that time - status() should only be called once, when the
exception is about to be passed to C code.
Here's my current replacement base class:
class BaseException :
public std::exception {
public:
virtual void what(StringEditor &str) const = 0;
virtual long status() const {
return S_exc_exception;
- Andrew
There is no S in exprexxo.
- Re: 3.15 C++ Exception classes Kay-Uwe Kasemir
- RE: 3.15 C++ Exception classes Jeff Hill
Re: DBD Syntax (Arrays) Marty Kraimer
<2006>
<2006>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
