Jeff Hill wrote:
Pursuing this a bit further, I notice, using epicsThreadShowAll, that the
OSI => OSD priority mapping maybe isn't working on POSIX (the OSSPRI
column
is always zero)?
Again, this is building with USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES.
Two "features" of priority scheduling on linux.
1) On linux you must be running as root in order to be able to set
SCHED_FIFO.
The code is written to silently revert to non-priority scheduling if
EPERM is returned.
2) Older versions of linux (perhaps all 2.4 versions without special
patches) do not seem to support priority scheduling. The implementations
seem to just silently ignore the priority scheduling requests even
though _POSIX_THREAD_PRIORITY_SCHEDULING is defined.
This it seems that the only way to know if priority scheduling is being
used is to run epicsThreadShowAll and see if the OSS prioritys have non
zero values.
Note that solaris shows non-zero values WITHOUT being root. When I run
top, I notice that the LWP has higher values than other processes. I do
not know how solaris is managing the priorities.
Marty
- Re: priorities Eric Norum
- RE: priorities Jeff Hill
Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Marty Kraimer
Re: R3.14.8 Status/logClient patch Benjamin Franksen
<2005>
<2005>
