2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsThreadSetPriority called by non epics thread
To: [email protected]
Cc: Shifu Xu <[email protected]>
Date: Mon, 21 Nov 2005 08:29:19 -0600
Andrew,
Thanks for finding the missing isEpicsThread.
I fixed the memory leak.
I added two new fields to epicsThreadOSD
isFifoScheduled
isOnThreadList
isOnThreadList is set when the thread is added to the list. Thus ellDelete is only called if this is true isFifoScheduled is used by epicsThreadSetPriority. If not true epicsThreadSetPriority. silenly does not try to call posix routines to set the priority. I do not know if this is necessary but it may be on some posix implementations.
I have no way to test on my linux because it is old and does not seem to support priority scheduling.
I will get Shifu to test on his linux systems which do.
Jeff and Earnest,
Can you try again?
Marty
Andrew Johnson wrote:
Jeff Hill wrote:
One has to configure the build setting "USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES" on Linux in order to see these messages occurring whenever a client
connects.
Interesting - with that setting I can replicate this on our 2-processor linux server (saturn) but not on my 1-processor linux workstation (apsajnt). I noticed that Jeff was running on an SMP kernel, and I assume his machine has more than one CPU:
Linux version 2.4.21-20.ELsmp ([email protected]) (gcc
version 3.2.3 20030502 (Red Hat Linux 3.2.3-42)) #1 SMP Wed Aug 18 20:46:40
EDT 2004
My boxes look like this:
saturn% cat /proc/version
Linux version 2.4.20-28.8smp ([email protected]) (gcc version 3.2 20020903 (Red Hat Linux 8.0 3.2-7)) #1 SMP Thu Dec 18 12:25:21 EST 2003
apsajnt% cat /proc/version
Linux version 2.4.20-19.9 ([email protected]) (gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)) #1 Tue Jul 15 17:18:13 EDT 2003
Looking at the code in libCom/osi/os/posix/osdThread.c I can now see the problem and explain why it's only happening on SMP systems.
This code is from epicsThreadCreate():
    pthreadInfo = init_threadInfo(name,priority,stackSize,funptr,parm);
    if(pthreadInfo==0) return 0;
    pthreadInfo->isEpicsThread = 1;
    setSchedulingPolicy(pthreadInfo,SCHED_FIFO);
    status = pthread_create(&pthreadInfo->tid,&pthreadInfo->attr,
                start_routine,pthreadInfo);
    if(status==EPERM){
pthreadInfo = init_threadInfo(name,priority,stackSize,funptr, parm);
The code creates a threadInfo object and calls setSchedulingPolicy(). If the subsequent pthread_create() call fails with an EPERM, it tries again without the setSchedulingPolicy(). There are two problems with this: a memory leak, since it never frees the original threadInfo object, and it doesn't set the isEpicsThread flag on the retry. My conjecture is that on an SMP linux kernel pthread_create() does actually return EPERM if the user isn't root, whereas on my single processor (UP) kernel it just accepts (and probably ignores) the thread priority request without error. I have tried running the IOC as root on my workstation, and epicsThreadShowAll lists all the threads with a zero for OSSPRI so it seems that the UP kernel completely ignores the thread priority. Unfortunately I don't have the ability to run the IOC as root on the SMP system, so I can't confirm my guess that way.
I have committed a fix to the second problem (forgetting to set the isEpicsThread flag) which removes the messages Jeff was seeing, but the memory leak is harder to fix since the free_threadInfo() routine tries to remove the threadInfo object from a list which it hasn't been added to yet. From the CVS history I see that Marty has already reworked this section of code a bit; I'm going to leave it for him to decide how to fix (there's a FIXME: comment at the relevent line).
- Andrew
Re: epicsThreadSetPriority called by non epics thread Ernest L. Williams Jr.
RE: epicsThreadSetPriority called by non epics thread Jeff Hill
Re: epicsThreadSetPriority called by non epics thread Andrew Johnson
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: Re: linux-x86_64 issue: epicsThread: Unknown C++ exception in thread "timerQueue" Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: epicsThreadSetPriority called by non epics thread Jeff Hill
Next: Re: epicsThreadSetPriority called by non epics thread Ernest L. Williams Jr.
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
