On Wed, 2005-11-16 at 08:39 -0600, Marty Kraimer wrote:
> I found the cause of the crash.
> The problem was calling epicsThreadSetPriority from a thread not created
> via epicsThreadCreate.
> I committed the change and a change to epicsThreadTest.cpp to test
> epicsThreadSetPriority.
Thanks Marty; it even works on 64-bit linux as well:
[williams@dragon linux-x86_64]$ epicsMessageQueueTestHost
Simple single-thread tests.
Should have 1 used -- Message Queue Used:1 Slots:4
Should have 2 used -- Message Queue Used:2 Slots:4
Should have 3 used -- Message Queue Used:3 Slots:4
Should have 4 used -- Message Queue Used:4 Slots:4
Test sender timeout.
Test receiver with timeout.
Single receiver with invalid size, single sender tests.
Single receiver, single sender tests.
epicsThreadSetPriority called by non epics thread
Systems with priority-based scheduler should send only
4 or 5 messages (sender priority > receiver priority).
Sent 5 messages.
Systems with strict priority-based scheduler should send
10 messages (sender priority < receiver priority).
Sent 5 messages.
All systems should send 10 messages (sender pauses
after sending each message).
Sent 10 messages.
Single receiver, multiple sender tests.
The following test takes 5 minutes to run and has succeeded
if nothing appears between here....
......and here.
Sender 1 -- 5845 messages
Sender 2 -- 5863 messages
Sender 3 -- 5908 messages
Sender 4 -- 5882 messages
Ernest
> When I run epicsMessageQueueTestHost on solaris it never terminates but
> does do everthing it should???
> Marty
- Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Marty Kraimer
Re: mrkSoftTest doesn't compile Ralph Lange
<2005>
FW: error log facility Jeff Hill
<2005>
