Janet Anderson wrote:
Are you
defining EPICS_BASE in the base/configure files?
No.
This
would override
your setting in mrkSoftTest/configure/RELEASE and explain the -L
options.
What are your modifications to the base/configure/files?
Nothing serious or extraordinary:
mare: .../3-14-X/configure > cvs diff
cvs diff: Diffing .
Index: CONFIG_COMMON
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/configure/CONFIG_COMMON,v
retrieving revision 1.109.2.15
diff -r1.109.2.15 CONFIG_COMMON
395c395
Index: CONFIG_SITE
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/configure/CONFIG_SITE,v
retrieving revision 1.42.2.7
diff -r1.42.2.7 CONFIG_SITE
92,93c92,94
< CROSS_COMPILER_TARGET_ARCHS=
< #CROSS_COMPILER_TARGET_ARCHS=vxWorks-68040
> CROSS_COMPILER_TARGET_ARCHS= vxWorks-68040 vxWorks-ppc603
vxWorks-ppc604_long
99c100
< CROSS_COMPILER_HOST_ARCHS=
> CROSS_COMPILER_HOST_ARCHS=linux-x86
171c172
< USE_POSIX_THREAD_PRIORITY_SCHEDULING = NO
> USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
Index: CONFIG_SITE_ENV
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/configure/CONFIG_SITE_ENV,v
retrieving revision 1.9.2.3
diff -r1.9.2.3 CONFIG_SITE_ENV
43,44c43,44
< EPICS_TIMEZONE=CUS::360:040202:102902
< #EPICS_TIMEZONE=MET::-60:032602:102902
> #EPICS_TIMEZONE=CUS::360:040202:102902
cvs diff: Diffing os
Index: os/CONFIG_SITE.Common.hpux-parisc
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG_SITE.Common.hpux-parisc,v
diff -r1.1 CONFIG_SITE.Common.hpux-parisc
18c18
< SHRLIB_SEARCH_DIRS +=
/opt/epics/R$(EPICS_VERSION).$(EPICS_REVISION).$(EPICS_MODIFICATION)/support/base/$(EPICS_VERSION)-$(EPICS_REVISION)-$(EPICS_MODIFICATION)-$(EPICS_UPDATE_NAME)$(EPICS_UPDATE_LEVEL)/lib/$(EPICS_HOST_ARCH)
/opt/epics/R$(EPICS_VERSION).$(EPICS_REVISION).$(EPICS_MODIFICATION)/base/$(EPICS_VERSION)-$(EPICS_REVISION)-$(EPICS_MODIFICATION)-$(EPICS_UPDATE_NAME)$(EPICS_UPDATE_LEVEL)/lib/$(EPICS_HOST_ARCH)
Index: os/CONFIG_SITE.Common.linux-x86
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG_SITE.Common.linux-x86,v
retrieving revision 1.8.2.4
diff -r1.8.2.4 CONFIG_SITE.Common.linux-x86
19a20,21
/opt/epics/R$(EPICS_VERSION).$(EPICS_REVISION).$(EPICS_MODIFICATION)/support/base/$(EPICS_VERSION)-$(EPICS_REVISION)-$(EPICS_MODIFICATION)-$(EPICS_UPDATE_NAME)$(EPICS_UPDATE_LEVEL)/lib/linux-x86
22a25,26
> LDLIBS_READLINE = -lreadline -lncurses
Index: os/CONFIG_SITE.Common.vxWorksCommon
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/Attic/CONFIG_SITE.Common.vxWorksCommon,v
retrieving revision 1.1.2.1
diff -r1.1.2.1 CONFIG_SITE.Common.vxWorksCommon
8c8,9
< VX_DIR = /usr/local/vw/tornado202p1
> VX_DIR = /opt/vxworks/tornado202
> #VX_DIR = /usr/local/vw/tornado202p1
cvs diff: Diffing tools
Do you
have an
EPICS_BASE environment variable?
No.
Thanks for your help - I'm really without a real clue what's going on.
Ralph
Ralph
Lange wrote:
That's how I would expect things to work, but
it's not working correctly.
Again - the generic location is determined from declarations in
BASE/configure/CONFIG_BASE_VERSION, which are setting the version info
for a 3.14.7 - even though that Base really is the future 3.14.8.
Again my suggestion: BASE/configure/CONFIG_BASE_VERSION should be
updated immediately *after* a shipping out a release to point to the
next release number. Then the generic path would be non-existing while
I'm compiling and testing a new base.
My mrkSoftTest's configure/RELEASE file contains:
#RELEASE Location of external products
EPICS_BASE=/home/unix/lange/work/epics/APS/epics/base/3-14-X
VX_STATS=/home/unix/lange/work/epics/APS/epics/vxStats
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
MSI=/home/controls/epics/extensions/bin/$(EPICS_HOST_ARCH)/msi$(HOSTEXE)
EPICS_EXTENSIONS=/home/unix/lange/work/epics/APS/epics/extensions
That's all that is in there - the generic location is not mentioned at
all, the local build location is first.
Nevertheless, the configuration files in EPICS Base are setting the
generic location as an argument to the -L linker option. This is not
the desired behaviour and should be fixed. In Base, not in mrkSoftTest.
Ralph
Andrew Johnson wrote:
Hi Ralph,
Ralph Lange wrote:
Is it illegal to use two compiled-in paths? From first glance I
wouldn't see why.
Does the build system rely on just one path being defined? If so: Is
that limitation justified?
There is no problem having more than one path defined (it will just
look through them one after the other until it finds the .so file), but
you must ensure that it will never find a different version of the
libraries at runtime than it saw at compile time, as I think I wrote
yesterday - your 'final install' path should be pointing to an empty or
non-existent directory until that version of base has been installed.
You might also want to adjust the search order so it looks in the local
build first by changing the order of the items in your mrkSoftTest's
configure/RELEASE file; shared library searches should occur in the
same order as the lines in that file.
- Andrew
- mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Andrew Johnson
Re: [Fwd: R3.14.8 testing: epicsMessageQueueTestHost fails on linux-x86] Ernest L. Williams Jr.
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
