That's how I would expect things to work, but it's not working correctly.
Again - the generic location is determined from declarations in
BASE/configure/CONFIG_BASE_VERSION, which are setting the version info
for a 3.14.7 - even though that Base really is the future 3.14.8.
Again my suggestion: BASE/configure/CONFIG_BASE_VERSION should be
updated immediately *after* a shipping out a release to point to the
next release number. Then the generic path would be non-existing while
I'm compiling and testing a new base.
My mrkSoftTest's configure/RELEASE file contains:
#RELEASE Location of external products
EPICS_BASE=/home/unix/lange/work/epics/APS/epics/base/3-14-X
VX_STATS=/home/unix/lange/work/epics/APS/epics/vxStats
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
MSI=/home/controls/epics/extensions/bin/$(EPICS_HOST_ARCH)/msi$(HOSTEXE)
EPICS_EXTENSIONS=/home/unix/lange/work/epics/APS/epics/extensions
That's all that is in there - the generic location is not mentioned at
all, the local build location is first.
Nevertheless, the configuration files in EPICS Base are setting the
generic location as an argument to the -L linker option. This is not the
desired behaviour and should be fixed. In Base, not in mrkSoftTest.
Ralph
Andrew Johnson wrote:
Hi Ralph,
Ralph Lange wrote:
Is it illegal to use two compiled-in paths? From first glance I
wouldn't see why.
Does the build system rely on just one path being defined? If so: Is
that limitation justified?
There is no problem having more than one path defined (it will just
look through them one after the other until it finds the .so file),
but you must ensure that it will never find a different version of the
libraries at runtime than it saw at compile time, as I think I wrote
yesterday - your 'final install' path should be pointing to an empty
or non-existent directory until that version of base has been
installed. You might also want to adjust the search order so it looks
in the local build first by changing the order of the items in your
mrkSoftTest's configure/RELEASE file; shared library searches should
occur in the same order as the lines in that file.
- Andrew
- mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Andrew Johnson
[Fwd: RE: Patches to support linux-arm for EPICS base] Andrew Johnson
<2005>
<2005>
