Hi Ralph,
Ralph Lange wrote:
Is it illegal to use two compiled-in paths? From first glance I wouldn't
see why.
Does the build system rely on just one path being defined? If so: Is
that limitation justified?
There is no problem having more than one path defined (it will just look
through them one after the other until it finds the .so file), but you
must ensure that it will never find a different version of the libraries
at runtime than it saw at compile time, as I think I wrote yesterday -
your 'final install' path should be pointing to an empty or non-existent
directory until that version of base has been installed. You might also
want to adjust the search order so it looks in the local build first by
changing the order of the items in your mrkSoftTest's configure/RELEASE
file; shared library searches should occur in the same order as the
lines in that file.
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
- Re: mrkSoftTest doesn't compile Ralph Lange
- mrkSoftTest doesn't compile Ralph Lange
Re: R3.14.8 Status/logClient patch Marty Kraimer
<2005>
<2005>
