On Wednesday 16 November 2005 21:56, Jeff Hill wrote:
> Ben,
> I did think of one issue. This is using non blocking IO after the
> connect completes. It appears that a delta is that the logRestart
> thread is now doing the periodic flush for *multiple* logging
> circuits. Therefore, if one of the log circuits isnt flowing for
> whatever reason (disk full, marginal circuit, server system power
> off, etc), then all of the other log circuits will not be flushed
> untill logClientSend is called and the specified message will not fit
> (the buffers capacity is exceeded). Since the internal IP kernel
> timeouts for circuit disconnect can be quite long this might prove to
> be problematic.
I see. I need to think about a solution. Thanks for the hint.
Cheers,
Ben
- RE: R3.14.8 Status/logClient patch Jeff Hill
Re: epicsAtExit Andrew Johnson
Re: epicsAtExit Kay-Uwe Kasemir
<2005>
Re: R3.14.8 Status/logClient patch Benjamin Franksen
<2005>
