2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: epicsAtExit
To: [email protected]
Date: Wed, 16 Nov 2005 14:17:45 -0600
I talked to Jeff awhile ago and we agree that there is a big problem with epicsAtExit.
I added an epicsAtExit handler to dbCa that stops the dbCaTask after calling ca_context_destroy. When this happened on linux using real time priorities an assert failure occured when a db_post_event occured
for a record the was the target of a CP link.
After talking to Jeff I think I agree that we can do one of two things
1) Dont do any cleanup, i.e. just do what we did on 3.13 on vxWorks with the exception of rebootHookAdd 2) Completely clean up the IOC database, i.e. make all device support terminate or at the very least all soft support
and make the record stop
If we try for half way measures there will probably always be problems.
I commented out the code in epicsExitCallAtExits and tried exampleApp on linux (with priorities) and on solaris. I had the example sequence program runing. I terminated both via exit and Ctl/C. The exampleApp always terminated properly.
So why did we invent epicsAtExit?
Does anyone remember?
Marty
Re: epicsAtExit Andrew Johnson
RE: dbEvent.c line 665 Jeff Hill
Prev: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Next: RE: R3.14.8 Status/logClient patch Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: dbEvent.c line 665 Jeff Hill
Next: Re: epicsAtExit Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
