2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: R3.14.8 Status
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Cc: "Abbott, MG \(Michael\)" <[email protected]>
Date: Wed, 16 Nov 2005 07:36:51 -0000
Apologies. I have been meaning to reply to the talk-talk post about linux-xscale since it was posted on the day I sent you the patch for linux-arm. What timing eh! I will certainly try to do a merge of the two concepts, though I suspect we will need direction on the naming.
I would certainly prefer to define a float format that applies and switch it on/off depending on the architecture, rather than make all the changes depend on #ifdef __arm__ (or similar). I assume that finds favour.
The real question is what to call the architecture. I shall assume linux-arm for now, but would welcome input.
In the followups to the original linux-xscale post, there was also mention of some patches already in CVS for an arm target. I will also try to roll these in.
-----Original Message-----
Sent: Tue 15/11/2005 19:18
To: EPICS core-talk
Subject: R3.14.8 Status
[snip]
Peter Dennison from Diamond sent me a set of patches for linux-arm which
included very similar changes to those that Peter Milne's patch (URL
sent to tech-talk on 11/8) supports, but with a different target
architecture name.  I'd prefer that we only have one linux-arm target
architecture if we can combine the two, possibly using the same approach
we took for linux-x86 vs linux-386/486/586/686 targets as regards
optimization if that's necessary.  Neither set of configure files is
currently in CVS, and using  #ifdef _armv4l_  may not be the best
solution - Jeff, should we make this more generic by adding a
CA_IMPURE_ENDIAN configuration macro?  I'll ask the two Peters to try
and come up with a common set of configure files for linux-arm if they
can for the R3.14.9 release.
[snip]
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11 0DE
+44 1235 778511
R3.14.8 Status Andrew Johnson
Prev: dbEvent.c line 665 Andrew Johnson
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: R3.14.8 Status Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
