I built the latest R3-14-2_branch against linux-x86_64 and ran a few
tests in libCom/tests. All tests were successful; except
"epicsMessageQueueTestHost"
[williams@sns-hp-eval1 O.linux-x86_64]$ epicsMessageQueueTestHost
Simple single-thread tests.
Should have 1 used -- Message Queue Used:1 Slots:4
Should have 2 used -- Message Queue Used:2 Slots:4
Should have 3 used -- Message Queue Used:3 Slots:4
Should have 4 used -- Message Queue Used:4 Slots:4
Test sender timeout.
Test receiver with timeout.
Single receiver with invalid size, single sender tests.
Single receiver, single sender tests.
Segmentation fault
========== Results from GDB ============================================
Core was generated by `epicsMessageQueueTestHost'.
Program terminated with signal 11, Segmentation fault.
Reading symbols
from /ade/epics/supTop/base/R3-14-2_branch-Oct-28-2005/lib/linux-x86_64/libCom.so...done.
Loaded symbols
for /ade/epics/supTop/base/R3-14-2_branch-Oct-28-2005/lib/linux-x86_64/libCom.so
Reading symbols from /usr/lib64/libstdc++.so.6...done.
Loaded symbols for /usr/lib64/libstdc++.so.6
Reading symbols from /lib64/tls/libm.so.6...done.
Loaded symbols for /lib64/tls/libm.so.6
Reading symbols from /lib64/libgcc_s.so.1...done.
Loaded symbols for /lib64/libgcc_s.so.1
Reading symbols from /lib64/tls/libc.so.6...done.
Loaded symbols for /lib64/tls/libc.so.6
Reading symbols from /lib64/tls/libpthread.so.0...done.
Loaded symbols for /lib64/tls/libpthread.so.0
Reading symbols from /usr/lib64/libreadline.so.4...done.
Loaded symbols for /usr/lib64/libreadline.so.4
Reading symbols from /usr/lib64/libncurses.so.5...done.
Loaded symbols for /usr/lib64/libncurses.so.5
Reading symbols from /lib64/tls/librt.so.1...done.
Loaded symbols for /lib64/tls/librt.so.1
Reading symbols from /lib64/ld-linux-x86-64.so.2...done.
Loaded symbols for /lib64/ld-linux-x86-64.so.2
#0 0x0000003224307333 in pthread_setschedparam ()
(gdb) bt
#1 0x0000002a95587fad in epicsThreadSetPriority (pthreadInfo=0x503ec0,
priority=Variable "priority" is not available.
at ../../../src/libCom/osi/os/posix/osdThread.c:513
#2 0x0000000000401a2d in epicsMessageQueueTest ()
at ../epicsMessageQueueTest.cpp:217
#3 0x0000000000400f59 in main () at ../epicsMessageQueueTestMain.cpp:22
Other interesting tests:
[williams@sns-hp-eval1 O.linux-x86_64]$ epicsThreadTestHost
It takes 0.009640 micro sec to call epicsThreadGetIdSelf ()
Estimating sleep quantum..........done
The epicsThreadSleepQuantum() call returns 0.010000 sec.
This doesnt match the quantum estimate of 0.004096 sec within 10%.
threadTest starting
threadTest created 0 myThread 0x5054b0
startPriority 50 minPriority 0 maxPriority 99
threadTest created 1 myThread 0x5059f0
threadFunc 0 starting argvalue 0x5059b0
threadFunc 1 starting argvalue 0x505ef0
NAME EPICS ID PTHREAD ID OSIPRI OSSPRI STATE
_main_ 0x5031b0 0 0 0 OK
errlog 0x505280 1074010464 10 0 OK
task0 0x505800 1074280800 50 0 OK
task1 0x505d40 1074551136 51 0 OK
threadFunc 0 stopping argvalue 0x5059b0
threadFunc 1 stopping argvalue 0x505ef0
epicsThreadTest returning
main terminating
[williams@sns-hp-eval1 O.linux-x86_64]$ epicsTimerExampleHost
first
epicsTime: Tue Nov 08 2005 06:53:14.807675000
second
epicsTime: Tue Nov 08 2005 06:53:15.308651000
[williams@sns-hp-eval1 O.linux-x86_64]$ epicsThreadPrivateTestHost
It takes 0.006440 micro sec to call epicsThreadPrivateGet()
[williams@sns-hp-eval1 O.linux-x86_64]$ epicsTimerTestHost
delay error > 0.5 %, delay = 0.6 s, error = -3.189 ms (0.531500 %)
delay error > 0.5 %, delay = 0.5 s, error = -3.186 ms (0.637200 %)
delay error > 0.5 %, delay = 0.4 s, error = -3.183 ms (0.795750 %)
delay error > 0.5 %, delay = 0.3 s, error = -3.18 ms (1.060000 %)
delay error > 0.5 %, delay = 0.2 s, error = -3.177 ms (1.588500 %)
delay error > 0.5 %, delay = 0.1 s, error = -3.173 ms (3.173000 %)
average timer delay error -3.208440 ms
test complete
[williams@sns-hp-eval1 O.linux-x86_64]$ epicsTimeTestHost
epicsTime Test (100 loops)
Time per call to epicsTime::getCurrent() (100000 calls) = 1.709 usec
The following should be your local time
displayed using four different internal representations:
epicsTimeStamp = Tue Nov 8 06:54:07 2005
254578000 nSec
local time zone struct tm = Tue Nov 8 06:54:07 2005
0.254578
struct timespec = Tue Nov 8 06:54:07 2005
0.254578
UTC struct tm = Tue Nov 8 11:54:07 2005
0.254578
epicsTime: Tue Nov 08 2005 06:54:07.254578000
epicsTime: revision "@(#) EPICS 3.14.7, Common Utilities Library Nov 4
2005"
... now at loop 10
... now at loop 20
... now at loop 30
... now at loop 40
... now at loop 50
... now at loop 60
... now at loop 70
... now at loop 80
... now at loop 90
epicsTime test complete. Summary: 0 errors found in 0 out of 100 loops.
Re: 3.14.8 and mrkSoftTest Ernest L. Williams Jr.
3.14.8@Linux: epicsMaxThreadsHost does not return Ralph Lange
<2005>
Re: 3.14.8: blockingSockTest - assert() fails. Ralph Lange
<2005>
