2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: 3.14.8 and mrkSoftTest
To: Marty Kraimer <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 08 Nov 2005 07:08:05 -0500
On Tue, 2005-11-08 at 07:01 -0500, Ernest L. Williams Jr. wrote:
> On Tue, 2005-11-08 at 05:46 -0600, Marty Kraimer wrote:
> > On Nov 8, 2005, at 5:30 AM, Ernest L. Williams Jr. wrote:
> > > The following is new for Linux:
> > > # Use POSIX thread priority scheduling (YES or NO)
> > > USE_POSIX_THREAD_PRIORITY_SCHEDULING = YES
> > > However, I think there are tests in <..>/src/libCom/test, right?
> > > I hoping for an advantage on linux-based softIOCs.
> > Yes that test works.
> > Also on any ioc run
> > epicsThreadShowAll
> > If the OSS priorities have values, i.e. not all 0, then you are
> > getting priority scheduling.
> > Remember that you must run the ioc as root.
> Awesome:
> Here are the results for a linux-x86_64 softIOC:
> Normal User:
> epics> epicsThreadShowAll
>             NAME     EPICS ID   PTHREAD ID   OSIPRI  OSSPRI  STATE
>           _main_     0x505d20            0      0       0       OK
>           errlog     0x50b470   1074010464     10       0       OK
>           taskwd     0x57a990   1074280800     10       0       OK
>       timerQueue     0x511ff0   1074813280     70       0       OK
>            cbLow     0x578810   1075870048     59       0       OK
>         cbMedium     0x580090   1075341664     64       0       OK
>           cbHigh     0x584220   1077455200     71       0       OK
>         dbCaLink     0x5845d0   1076398432     50       0       OK
>         scanOnce     0x587af0   1078511968     70       0       OK
>           scan10     0x588460   1079568736     60       0       OK
>            scan5     0x5887c0   1080625504     61       0       OK
>            scan2     0x588b20   1081682272     62       0       OK
>            scan1     0x589380   1077983584     63       0       OK
>          scan0.5     0x5895c0   1082739040     64       0       OK
>          scan0.2     0x589920   1083795808     65       0       OK
>          scan0.1     0x589c80   1084852576     66       0       OK
>        CAC-event     0x5ba2c0   1084324192     52       0       OK
>          CAS-TCP     0x5c7270   1083267424     16       0       OK
>       CAS-beacon     0x50b600   1073875296     14       0       OK
>          CAS-UDP     0x50a420   1076926816     12       0       OK
> epics>
> Root User:
>           errlog     0x50b190   1073875296     10      10       OK
>           taskwd     0x57a0a0   1074010464     10      10       OK
>       timerQueue     0x57bce0   1074276704     70      69       OK
>            cbLow     0x57b5b0   1074805088     59      58       OK
>         cbMedium     0x511e70   1075333472     64      63       OK
>           cbHigh     0x5120b0   1075861856     71      70       OK
>         dbCaLink     0x511540   1076390240     50      50       OK
>         scanOnce     0x5873d0   1076918624     70      69       OK
>           scan10     0x587bd0   1077447008     60      59       OK
>            scan5     0x587dc0   1077975392     61      60       OK
>            scan2     0x587fb0   1078503776     62      61       OK
>            scan1     0x5881a0   1079032160     63      62       OK
>          scan0.5     0x588390   1079560544     64      63       OK
>          scan0.2     0x588580   1080088928     65      64       OK
>          scan0.1     0x588770   1080617312     66      65       OK
>        CAC-event     0x5b8b10   1080883552     52      51       OK
>          CAS-TCP     0x5c5a30   1081149792     16      16       OK
>       CAS-beacon     0x5c5c40   1081284960     14      14       OK
>          CAS-UDP     0x5c5e60   1081551200     12      12       OK
> epics>
Oops.  I get an exception when exiting the IOC as root:
epics> exit
epicsThread: Unknown C++ exception in thread "timerQueue" at Tue Nov 08
2005 07:01:33.72157000
Segmentation fault
[root@sns-hp-eval1 iocamd64]#
I will run all of this again on 32-bit linux
> Thanks,
> Ernest
> > Marty
3.14.8 and mrkSoftTest Ralph Lange
Re: 3.14.8 and mrkSoftTest Marty Kraimer
Re: 3.14.8 and mrkSoftTest Ernest L. Williams Jr.
Prev: Re: 3.14.8 and mrkSoftTest Ernest L. Williams Jr.
Next: More testing on linux-x86_64 Ernest L. Williams Jr.
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: 3.14.8: blockingSockTest - assert() fails. Ralph Lange
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
