At 1:23 PM -0600 2005/10/17, Jeff Hill wrote:
Proper uniform definition of connection responsiveness notification
interfaces is also a very important issue that is often overlooked in a
first cut CORBA based approach. In any case that was what the reviewers
commented about initial efforts at NIF.
I was one of those early reviewers. Although we did not see the full
negative implications and coupling of the wide, early-binding
interfaces, we did notice the fundamentally synchronous nature of the
CORBA in use (again, the available vendors did not support the event
system and some other CORBA features).
Much was done (by the vendors and the NIF developers) to mitigate
this, but when either a tier-1 or tier-2 program dies, often it is
not possible to smoothly re-insert it into the mesh of still running
programs in all 3 tiers. There are also messages queued up deep in
the (opaque) CORBA and TCP/IP layers that "assault" a newly restarted
IOC and can cause it to fail again. Often the only recourse is to
tear down a substantial block of tier-1, -2, and -3 programs and
restart them in a benign order.
A non-solution is the practice of storing the dynamic connection
information (CORBA references) back in the RDB: after a really nasty
crash, the RDB has to be (manually) scrubbed, since no starting order
works. This might have implications for a central nameserver in a
3-tier EPICS system--unless you think there will be no "nasty
crashes" ever :-)
- Re: ICALEPCS and EPICS iocCore V4 Claude Saunders
- RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
