At 2:14 PM -0400 2005/10/17, Kay-Uwe Kasemir wrote:
But back to the technical aspect, did NIF just pick the wrong
interfaces and thus each change requires 2-6?
Is the other OO framework talk mostly by people who
have never actually tried it on the scale of NIF?
Well, there are several aspects here. Because of the need for Ada
language bindings, there were few choices of CORBA vendors; none
offered Dynamic Invocation Interface. So a change of interface is a
very early binding.
There was one Java program that could access tier-1 (IOC) interfaces
as well as tier-2; when started at the command line, it dynamically
parsed *ALL* the IDL in the shop. You were then presented with a
pick list of 300-400 callable interfaces: you filled in the IN
parameters and back came the OUTs. (It took about 15 minutes to
start on a Sunblade 1000.)
The problem was that each object designer created whatever interfaces
they saw fit to support use cases as they came along. So in addition
to the "interesting" ones (like commands), every get/set for every
attribute required a semi-custom interface. What took the place of
the motor record, for example, had about 50 interfaces...
So the interfaces were not "wrong", but in a model where one
requirement -> one interface, then new interfaces (commands +
attributes) are an ongoing reality.
Adding new attributes to the motor record affects only a
sophisticated sequencers, say, that need to manipulate them; it does
not affect displays, archivers, alarm handlers, striptool, etc, etc,
as long as the list of channels is administratively dealt with
properly, as Kay suggests. That's very late binding.
- ICALEPCS and EPICS iocCore V4 Marty Kraimer
- Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
- Re: ICALEPCS and EPICS iocCore V4 Kay-Uwe Kasemir
RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
RE: ICALEPCS and EPICS iocCore V4 Steve Lewis
<2005>
Re: ICALEPCS and EPICS iocCore V4 Benjamin Franksen
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
