Marty Kraimer wrote:
Thus all the IOC database needs is a:
1) nonmutable reference counted continguous string. When the reference
count goes to 0 the storage can be reclaimed
Since you're writing thread-safe code, the reference count also has to
have an associated mutex to protect it from simultaneous updates from
two threads. Each string might have its own mutex, or we might rely on
a single central mutex to protect all reference counts - there are
advantages and disadvantages to either choice, although the former is
probably better for performance since there will be many fewer clashes.
Note that a published study has shown that in a threaded environment the
time to take and release the mutex around every increment/decrement
operation completely nullifies the speed advantage of using reference
counting over copying for a string implementation. I'm not claiming
this definitely applies in our case since their usage of the strings
differed from ours, but the performance hit from that mutex is something
to bear in mind. I'm also not convinced that the string itself is the
right place for the reference count when it's embedded in a larger data
structure like a field descriptor or record type descriptor.
We might need more than one implementation of the nonmutable string; one
where the storage is obtained from the system (new/malloc), and a second
where the storage is a char* literal that must not be freed when it's no
longer referenced. Compiling DBD files generates literals for record
type names, field names and menu choice strings. I think we should just
store the char* pointer in these cases without using any kind of string
wrapper - if any reference count exists it would have to apply to the
descriptor as a whole, not just to the name string.
In my design any const char* buffer or literal can be wrapped with a
ConstString at the point of use if it has to be passed to a routine that
takes a StringReader. Ownership would never be passed that way though.
What the IOC database needs for strings is very different than what
dataAccess requires.
However if we can agree on a common string API it will make the iocCore
code much easier to understand overall, and will probably save us from
duplication of common tasks. I believe that my current design is an
acceptable compromise, and so far nobody has raised any significant
objections to it.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
- RE: data access structures, strings Jeff Hill
- Re: data access structures, strings Marty Kraimer
- Re: data access structures, strings Kay-Uwe Kasemir
- Re: data access structures, strings Andrew Johnson
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
