2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: data access structures, strings
To: "'Kay-Uwe Kasemir'" <[email protected]>, <[email protected]>
Date: Fri, 23 Sep 2005 16:43:58 -0600
Kay,
> The users must pollute his data's interface with the
> PropertCatalog interface.
The typical user will probably not have data structures like RGBCatalog
deriving from propertyCatalog, but will instead create accessor objects that
implement propertyCatalog and also know RGBCatalog. I have written templates
that automate creation of these accessor objects. I presented examples at
our last meeting. I hope to have them in the DA manual (and CVS) soon. Based
on past experience, I will receive gripes if I check in something that isn't
finished.
> Seems to me that yes, dataAccess helps with handling
> containers with differing types for matching properties;
> Even containers with differing properties,
> but that only on the 'top' level.
> Anything one level down must match.
I think that it's a good idea to define standard names for the properties so
that client and servers are on the same page. For example, when we say
"precision" this needs to be well defined so that it means the same thing to
the client and the server. Likewise, standards should be specified for the
property hierarchy. For example, when we say display limits it should be
well understood that there is minimum set of subordinate properties required
of conformant servers.
> That's the situation where a pulling interface
> would be more obvious, because then I can write
> the mapping code
>    destination->r = data_catalog->find("color")->find("red")->toDouble()
I guess I don't understand the point here since its easy enough to write a
convenience library that implements "destination->r =
data_catalog->find("color")->find("red")->toDouble()" on top of the data
access minimalist interfaces. Note that data access is designed so that the
user needs to do very little to export his data. Many things can be layered
on top of these interfaces to improve usability in select situations.
> When I ask the propertyId->getName() to get the property name,
> why not return char * "value"?
> Instead it's
>      propertyId->getName(stringSegment s)
> and then propertyId will call
>      s->putChar('v'), s->putChar('a'), s->putChar('l'), ...
> That might sound like a very performant and memory-conserving
> idea for the channel access library,
> but the user of the library still would like to get the property
> name, and the required code probably reverses any CPU & mem savings.
Several reasons - see item #29 in "Effective C++" for a summary.
In particular, I worry about:
a) In multithreaded systems I tend to not write accessor methods that return
handles to internal data. The data might be changing while the user is using
it and does not have a lock.
b) I also worry that if we hand off a handle to internal data that the user
may still be using the pointer to the string after the property identifier
has been destroyed.
c) Returning a pointer to a string does not allow non-contiguous storage
(improved memory management).
You can come up with some usage patterns that eliminate some of these
concerns, but I am not thinking that way. I am trying to create a rock solid
interface design that works with multiple threads and isn't a create
everything during initialization and nothing gets destroyed type of system.
Given the inherent slowness of strings I don't think that block copying the
string out before you use it, in order to avoid the above concerns, is an
efficiency issue. Furthermore, with a simple implementation based on decent
fixed sized block memory management, I don't think that creating storage on
the fly for strings is inefficient from a memory management perspective.
Such string implementations would presumably provide convenience routines
for all of the common string functionalities. I am not interested in writing
a string library. I need an interface to string data that does not preclude
high performance (read properly memory managed) implementations.
Also, in select situations there isn't anything wrong with "char[20]" ( or
"malloc(20)" ) with a nill terminator on the end. We will undoubtedly
provide simple accessor objects implementing the StringSegment interface for
that type of string. There will of course be specialized accessor objects
for string constants also.
Finally, its probably a good idea to be consistent about all strings that
are passed in and out of the library. The advantage of StringSegment is that
it places very little constraint on how strings are stored - and it does not
require much work to interface a particular type of string. StringSegment
isn't trying to be a string implementation - its only trying to interface to
strings in a minimalist way.
Furthermore, I gave this list my perspective of the functional requirements
for this type of minimalist approach to interfacing to strings some time
back. None of this is locked in stone, and I would certainly like to hear
your perspective(s). By now you undoubtedly know my opinion on interfaces
that return a pointer to the entire string stored in one contiguous block
> StringSegment must copy characters out one a time
a) Once we adopt UTF-8 as the only way that wide characters are stored (I
think that we have pretty much reached this consensus at this point) then
the interface will be changed to include a character count in putChar and
getChar so that characters can be shipped in bulk.
b) The "StringSegment::read (StringSegment &)" and "StringSegment::write
(StringSegment &)" interface *do* allow down-casting using dynamic_cast for
a more efficient transfers in the common case where the source and
destination are the same character string implementation.
Interested in your perspective(s) on these issues
HTH (sorry if this was boring for those of you that have heard it before)
Jeff
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Friday, September 23, 2005 3:13 PM
> To: [email protected]
> Subject: data access structures, strings
> Hi:
> Assume I have this source data:
> struct RGB { int r, g, b; };
> struct data
>      double    value;
>      struct RGB color;
> I can implement a property catalog for the sub-struct:
> class RGBCatalog : public propertyCatalog
> {   void traverse ( propertyViewer &v) const
>          v.reveal(red_id, rgb->r);
> and then use that in the PC for the data:
> class DataCatalog : public propertyCatalog
> {   // constructor somehow gets pointer to 'data',
>      // prepares RGBCatalog 'color' for data->color
>          v.reveal(value_id, data->value);
>          v.reveal(color_id, color);
> OK. If I only want the 'value', I use
>     data_catalog->find(value_id, ...)
> and get a 'reveal' callback for the value.
> What if my target data is
> struct destination
>      double value;
>      int r, g, b;
> Is there a way to get
>     destination->r =  data -> color.r;
>     destination->g =  data -> color.g;
> As far as I see it, I can call
>     data_catalog->find(color_id, ...).
> That results in
>     reveal(color_id, propertyCatalog &color)
> for the whole propertyCatalog for color.
> the mapping code
> Instead it's
> -Kay
RE: data access structures, strings Jeff Hill
data access structures, strings Kay-Uwe Kasemir
Prev: data access structures, strings Kay-Uwe Kasemir
Next: RE: data access structures, strings Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
