These were the talks we planned for the collaboration meeting
Properties, events, filters Bob 15
Using Data access Kay 45
Version4 database Marty 45
Core meeting topics to be held Thusday evenning.
data access handling issues - discussion
how it addresses the epics office - and kay's doc.
(sales pitch to open office) (Andrew's JAVA implementation of DA)
how do events get handled - client side - bottom of database. - discussion
Protocol - Jeff
Office people should be at the EPICS core meeting
The raw notes are attached
Notes Sept 13
Read/write access request to data access. Andrew
Can be done when there is an instance Jeff
Ralph has a wiki to make this discussion Jeff
Shared components will be available Jeff
Type descriptions used in the database are different than channel access
types KaY
Not decided - will be an internal one Jeff
Can provide one --- Jeff
Use the database Kay
Can get a description beyond that Kay
Type code space - returns INT / size int
Can provide the database one as well Jeff
Redundant information....
Want a fixed enumerated set Kay
Want to support unsigned types Jeff
Protocol will support any type space Jeff
Need to present this. Jeff
Needs to be able to say what the native type Jeff
Start out supporting the database types Kay
What about link fields?
V4 DBD doc says what will be available Marty
structures, strings, timestamps, enums Marty
Andrew's wiki has standard name of the properties Jeff
List will contain all basic types Kay
Database has distinction between menu and enum - link and structure Kay
To change a link dynamically you need Marty
string that is the code to handle it
structure with data to configue the device
the dbd interface will get structure / string
Identifier is for the internal use of the datbase. Andrew
Imagines that links has subordinate properties - Andrew
what kind of link ca, db, hw
associated - address information
other subordinate propwerties - PP and MS
should support those over channel access - Andrew
So the new platform should allow this proprty to go across - Jeff/Andrew
What about fields that now have PP property? - Andrew
TINE server doesn't have this
Introspection should allow this for a field - Jeff
(So we are requiring that the proerties of a field should also be sent?)
How do we implement a get with PP -- Andrew
Not in the API - add ability to add a message - properties Jeff
Get is a one shot subscription - for a flavor - Jeff
Transactions need to be supported - like put with get Kay/Andrew
Does data access already include the browsing and type info? Kay
Added to satisfy MArty's request.
Can user ask for subset of available properties....? Jeff
user does ca_put with property catelog -- ca needs to know this Kay
CA can just send what is requested and the request is denied Jeff
Use traverse in the data container - twice - once for size? once for data?
Can supply reference to property catelog and register a type Jeff
client gives back ticket for it (from server)
uses ticket from then on
writes may not need "dirty bit" compression Jeff
Want to see protocol before then ---- Andrew
Put it on the wiki--- Jeff
Data access does not tell you what the type is Kay
-- not checked into CVS
-- new document describes how one would define type Kay
-- doesn't tell you the type
-- browses the type.
Expose types not available publicly.... Kay
Could Jeff check this in? Kay
Present the most recent idea for data access -- Kay
Attempt to use it -- Kay
Sting interface is not well defined -- Andrew
No string interface to use -- Kay
Handle expose types and
Openoffice data access document from Matthias -- MArty
-- they talk about how to support all types --
-- if we are trying to solve the community --
Data access means property catelog -- Andrew
-- server interface is not yet defined
Need a more developed API for the server side -- Andrew
-- not how the sever side would use it
-- how would the server side use it
From both the client and server side --
Need a talk on exposing type..... Kay
Get the diagram of how all of the pieces fit together - Bob
Jeff to do CVS commit Andrew
Will send out the string library Andrew
Prperty catelog for the existing database Bob
Events and Filters TALK
Read the wiki page that Andrew produced
Deep tree more efficient that wide one
Version 4 database - defining record instances Marty
-- present this at the meeting
We want to hear what EPICS office people are doing for data interface - Bob
Data access converts to JAVA well Andrew
Should they adopt data access
45 minutes each.
Properties, events, filters (15)
Data access
Version4 database -
Core meeting -
Protocol
data access -- how it addresses the epics office - and kay's doc.
Propose a schedule - can do it as phone as well.
Phone access to the core meeting.
Provide talks to core members that will not be there.
- RE: Meeting Notes Jeff Hill
Data Access / status of CVS repository Ralph Lange
Re: Data Access / status of CVS repository Marty Kraimer
<2005>
RE: Data Access / status of CVS repository ky9
<2005>
