Hi:
On Aug 11, 2005, at 15:08, Jeff Hill wrote:
I had a look at your proposal....
I've been busy but finally got around to try data access,
based on the Aug. 23 snapshot. The result is on
http://www.aps.anl.gov/epics/wiki/index.php/V4_Data_Interface
I think that we can succinctly boil this down to two options.
Should this be
iterator based (..) or callback based (the DA approach).
YES! I'm convinced that many find
EpicsProperty *p = pc->findProperty("value");
double d;
p->getDouble(d);
easier to understand than handing control over
to a 'viewer' class
Viewer v;
pc->find(pi_value, v);
OK, data access visited the viewer's
reveal(pi_value, <native type>),
but now I have to hack around to get
the data deposited in a place that's accessible
from the line after 'find' where I want to
use the data.
Maybe dataAccess needs to include a set of these:
doubleViewer : public propertyViewer
public:
double d;
void reveal ( const propertyId &id, const double &v, const
propertyCatalog &x)
{ d = v; }
void reveal ( const propertyId &, const int &i, const
propertyCatalog &x)
{ d = v; }
Now I could write
doubleViewer dv;
pc->find(pi_value, dv);
cout "Value is " << dv.d
2) ....Let's look at storing the data in an application specific
proprietary
structure.
viewer.reveal ( propValue, ar_mutable, & MyContainer::value );
viewer.reveal ( propUnits, ar_mutable, & MyContainer::units );
viewer.reveal ( propPoint, ar_immutable, & MyContainer::point );
Consider what the user has to do with Kay's revised approach:
properties[0] = new EpicsDoubleProperty("value", &value);
properties[1] = new EpicsStringProperty("units", &units);
properties[2] = new EpicsStructureProperty("point", 2,
point_properties);
They look very similar in terms of ease of use to me.
Yes, very similar. Except when I actually try it with data access,
I run into 3 issues:
- the published version doesn't understand ar_mutable/ar_immutable,
so I have twice the code for now
- don't know how to interface with stringSegment,
so I had to skip the units.
- in order to reveal my struct point, it needs to be rewritten
to derive from propertyCatalog.
Does DataAccess interface structured user data 'as is'?
I only get that to work for scalars.
Sub-structures need to re-packaged as propertyCatalog-derived
classes.
O My perception is that callback is more efficient. With the
iterator and
abstract data descriptor approach I have to play the animal,
vegetable, or
mineral game with the data. I have to ask the property what is your
type,..
Almost. As the end user of the API, I _may_ ask, if I care,
for example if I'm a generic dumper that wants to dump any data type.
More often I simply say: getDouble().
If my property happens to be an
EpicsDoubleProperty, I get the double.
The other EpicsXXProperty classes have this default conversion:
bool getDouble(double &d)
int i;
if (!getInt(i)) return false;
d = i;
return true;
There is no 'switch(type)'.
Furthermore, the authors of MEDM, probe, or the gateway will
probably use a
common library (I think that Ralph is already in the preliminary
design
phase) for inflating storage for a set of properties that are
unknown at
compile time.
Yes, I think such a library is needed to make dataAccess usable.
-Kay
- RE: Channel Access Client Interface Jeff Hill
RE: Current copy of data access? Jeff Hill
R3.14.8 Release timetable Andrew Johnson
<2005>
Re: Channel Access Client Interface Benjamin Franksen
<2005>
