2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: String Interfaces
To: Jeff Hill <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Thu, 28 Jul 2005 10:46:39 -0500
Jeff Hill wrote:
Jeff: Would you accept something like this method in a string interface
class?
protected:
    virtual bool getSegment(size_t offset,
                 const char * & segment, size_t & len) const = 0;
My reservation about this is # 29 in Effective C++ 2nd edition - avoid
returning handles to internal data. I think that these concerns are
magnified in systems that have a) dynamically created and deleted strings,
b) dynamically modifiable string values, c) dynamically modifiable string
storage sizes, and d) have multiple threads accessing shared strings.
Can I request that you re-read the final paragraph of that EffC++ item.
In this case there *is* a compelling reason to allow other string implementations to get a pointer to your segment data; because it's impossible for two different segmented string types to work together efficiently (even assignment would have to be done character by character) otherwise.
Your concerns about multiple threads are irrelevent since if the string is not already properly protected by an external mutex it can be changed in between two character-by-character reads, which is probably breaking some other promise you made to the user of the string when you handed it out.
You're already presenting us with another API that requires us to give out handles to internal data: A propertyCatalog::traverse() function has to trust that the propertyViewer/propertyManipulator isn't going to take and store the address of the reference it has to give out.
If not, please describe how you would write an efficient comparison
operator between two different segmented string implementations.
Note the words I used: "two different segmented string implementations."
If not then we drop back to a slower generic version that
requires copying into a scratchpad, but since that situation will occur only
when crossing between subsystems or when transitioning from an old string
implementation to a new one then perhaps the overhead would be acceptable.
I disagree that this is acceptable, because I see it as being very common to have multiple implementations. I can see requirements for at the very least two if not three or four inside of iocCore, and that's before considering your needs inside of CA.
PS: I would also like to see strings accessed through a pure virtual
interface class so that multiple implementations are possible. This is,
among other apple pie reasons, because DA is interfacing with the world, and
the world will use many different string implementations including
std::string.
If you give me my request, I'll give you that one.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
RE: String Interfaces Jeff Hill
Prev: Re: next meeting before EPICS meeting at Archamps? Doug Murray
Next: RE: ICE and TIPC Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: String Interfaces Kay-Uwe Kasemir
Next: RE: String Interfaces Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
