2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: String Interfaces
To: "'EPICS Core Talk'" <[email protected]>
Date: Thu, 28 Jul 2005 09:10:06 -0500
This discussion is only of interest to C++ since a Java implementation would do something very different.
Even for C++ lets limit the discussion to what is needed for network accessable data. What network transport code needs for strings may be very different than what other code requires. Thus lets only discuss an interface for transfering network accessable strings. For example this is the interface that dataAccess can use for strings.
Kay has been asking for non segmented strings. Can this be done and still satisfy other requirements? Perhaps yes.
The following interface (defined in psuedo code) has the following attributes:
1) Does not expose internal storage.
2) Is a pure interface
3) Allows the user and implementer to use segmented or non-segmented storage for the strings
interface StringAccess {
   void setPutSize(int32 size);
   void put(int32 len, octet[] data);
   int32 getSize();
   void get(int32 len,octet[] data);
Code doing a put does the following:
1) Call setPutSize to say how many octets it will transfer
2) Call put as many times as it wants. Each put transfers an additional segment. The code implementing the interface MUST accept the total amount requested.
Code doing a get does the following:
1) Calls getSize tom see how much storage is required.
2) Calls get as many times as it wants. Each get transfers an additional segment. The code implementing the interface MUST return the total amount requested.
Thus the caller can either work with non segmented ir segmented strings. The implementer of the string can also use segmented or non-segmented strings but may have to block between segments.
Marty
Jeff Hill wrote:
Jeff: Would you accept something like this method in a string interface
class?
protected:
    virtual bool getSegment(size_t offset,
                 const char * & segment, size_t & len) const = 0;
My reservation about this is # 29 in Effective C++ 2nd edition - avoid
returning handles to internal data. I think that these concerns are
magnified in systems that have a) dynamically created and deleted strings,
b) dynamically modifiable string values, c) dynamically modifiable string
storage sizes, and d) have multiple threads accessing shared strings.
If not, please describe how you would write an efficient comparison
operator between two different segmented string implementations.
In the String Segment interface we have the following:
   virtual StringDiff compare ( const StringSegment & ) const = 0;
My conclusion was that it would be easy, and relatively efficient enough (we
need to remind ourselves that nothing is particularly efficient when we use
strings), to inside of the implementation of striongSegment::compare()
attempt to downcast the incoming StringSegment typed parameter using
dynamic_cast to the local type deriving from interface StringSegment. If
that cast is successful we are comparing two implementations of the same
type that we have private access to and we can implement a very fast and
efficient version. If not then we drop back to a slower generic version that
requires copying into a scratchpad, but since that situation will occur only
when crossing between subsystems or when transitioning from an old string
implementation to a new one then perhaps the overhead would be acceptable.
PS: I would also like to see strings accessed through a pure virtual
interface class so that multiple implementations are possible. This is,
among other apple pie reasons, because DA is interfacing with the world, and
the world will use many different string implementations including
std::string.
Jeff
RE: String Interfaces Jeff Hill
Prev: Re: ICE and TIPC Marty Kraimer
Next: Re: String Interfaces Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: String Interfaces Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
