2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: String Interfaces
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 27 Jul 2005 18:24:18 -0500
Kay-Uwe Kasemir wrote:
Being out of ideas, I looked at the NextStep/Apple Cocoa frameworks.
I like how it uses separate classes for static and mutable objects,
and suggest that the basic 'String' is read-only,
a 'MutableString' allows write access,
and there are container classes that create a string from char *,
sprintf-format etc. and present a 'String' or 'MutableString' interface.
Having two separate interfaces for const and mutable strings was something Eric mentioned a while back. I'm not sure that it's really necessary in C++ since the compiler already implements the distinction we need using const qualifiers, but programmers who are new to C++ might find it easier to understand and I don't see any major performance issues. Any design done one way should be easily converted to the other, so I'll go along with this suggestion for now.
However, as far as I can see the major point of contention with strings seems to be how you access the characters stored in the string.
Jeff was originally only offering one character at a time access in order to support wide character types, but he has conceded that if we standardize on UTF-8 everywhere then the wide character requirement goes away. To quote him:
> The StringSegment interface in data access certainly could be
> revised to allow blocks of characters to be read/written in UTF-8
> format (assuming that all strings are streams of octets).
The chief argument that I see then is whether the string interface should permit other code to access the character segments directly in its internal buffer, or whether they would have to be copied out to some other buffer first.
AIUI Jeff wishes to completely hide the internal string implementation, such that the only API that supports access to multiple characters at at time would be one that copies all or a section of the string to an external char* buffer.
In the blue corner, I think we should permit code that is willing to work with segmented strings to get at least a const char* pointer to a section of the string. There's a very good reason for this - it's needed to implement efficient operations between strings of different kinds. This access method can be protected so that only other string implementations can make use of it, but I don't see any way to implement assignment between or comparison of different string types efficiently otherwise.
Jeff: Would you accept something like this method in a string interface class?
protected:
    virtual bool getSegment(size_t offset,
                 const char * & segment, size_t & len) const = 0;
If not, please describe how you would write an efficient comparison operator between two different segmented string implementations.
I'll be back with more when I get an answer to this.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
RE: String Interfaces Jeff Hill
FW: Standard String Jeff Hill
Re: FW: Standard String Benjamin Franksen
Re: Standard String Kay-Uwe Kasemir
Re: Standard String Marty Kraimer
Network Accessable Data Marty Kraimer
Data Interfaces Kay-Uwe Kasemir
Prev: Data Interface (was: ICE & TIPC) Kay-Uwe Kasemir
Next: RE: ICE and TIPC Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Data Interfaces Kay-Uwe Kasemir
Next: RE: String Interfaces Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
