Kay-Uwe Kasemir wrote:
I suggest _not_ to allow con-contiguous storage.
I cannot imagine a server that keeps his
strings in segments.
I can; I am considering an implementation of variable length strings
that does not require the reallocation and copying of data as the string
is extended. This would use a fixed allocation size block, and chain
these blocks together as needed to make up the complete storage for the
string.
I understand why a network layer will _receive_
the data in pieces, but that's a problem of the
network layer.
All communications layers that I have seen so
far hide that detail from me.
With the proper environment variable configuration,
even CA V3 hands me the complete dbr_ctrl_double
for huge arrays,
so why obfuscate the V4 data access in order to
support non-contiguous data?
Any API that is designed to support segmented data can also support
contiguous data with no changes. An API that requires contiguous data
cannot be used with segmented data without copying all the data segments
into a contiguous buffer first, thus requiring extra memory and reducing
performance.
Eric Norum has an R3.14 IOC with very limited RAM that uses a waveform
record to allow its flash eprom to be reprogrammed, but his memory
requirements are such that he can only fit one waveform buffer in
memory. If we require another copy of the data this IOC would probably
not be able to fit in memory.
Since we're designing the APIs and they will hide all of the details
from user code, why would we make them less flexible?
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- Re: ICE and TIPC Kay-Uwe Kasemir
- ICE and TIPC Marty Kraimer
- Re: ICE and TIPC Ralph Lange
<2005>
<2005>
