Ralph Lange wrote:
While I generally agree with your requirements and descriptions, I don't
think we should make the network layer's on-the-wire types the central
type-defining instance. Let me give two reasons:
1. Learning the native type of data is part of the DA interface. The DA
interface is purely about data and does not have any notion of network
transport. An application may access things within a library or through
shared memory using DA without any network involved. Why should a
certain network layer define the data types when no network is used?
I'm not convinced that it's possible for us Muggles to do that
(translation: I think you're asking for magic).
I can create a DA container that has a property expressed in a new
application-specific 'absoluteTemperature' type. This is implemented as
a C++ wrapper around a double; it provides an implicit conversion to
double operator, and also has constructors and assignment operators that
take doubles. The type express an absolute temperature in Kelvin, and
the accessor functions ensure it can never holds a negative value. The
property type is definitely not a double though, and C++ is perfectly
capable of distinguishing the two.
Inside Data Access, each supported type has an overloaded reveal() entry
in the virtual function table of the propertySurveyor, propertyViewer
and propertyManipulator interfaces. If I want Data Access to natively
support my new 'absoluteTemperature' type, I have to extend those
interfaces and add a new reveal() function to all of the standard
surveyor, viewer and manipulator helper classes (converters etc).
That's a lot of work, and now I have a problem - I've changed the
signature of those propertyXxxx interfaces, so I can't link my version
of DA with the standard CA library any more.
Thus unless I modify Data Access and then completely recompile both DA
and CA, no other local DA object can know what my new type really is -
as far as they're concerned my absoluteTemperature properties would just
look like doubles. Unless I extended the CA protocol too, CA would
still have to transport them over the network using doubles and would
not be able to tell the difference (assuming the current interface).
2. Not only may a language map different on-the-wire types to the same
language-specific type, CA (or another network layer) itself might
consider to map different language specific-types to the same
on-the-wire type. In that case I would like the client to know the real
original native type of data on the server side and /not/ what something
inbetween chose to use for network transport.
I'm not convinced about the usefulness of this in practice - you don't
have any control over how the value gets transported. Even if you ask
for it as a string, the conversion will happen at the client end with
the V4 version of CA.
I see the next generation CA as a transparent network transport layer
for DA accessible data, so that the DA interface works the same local
and via network. A client application should not have to know and should
not even care what on-the-wire types CA uses to transport stuff.
I agree that a client shouldn't have to know that the network types are,
but that's not the same as saying DA has to be able to support every
data type. There will always have to be a mapping between a client type
and some network representation of values in that type.
I'm not saying that DA should *only* support the network types. I think
the propertyManipulator class should support all of the basic types
provided by the language, i.e. on C++: both signed and unsigned versions
of the integer types char, short, int, long and (if the platform
provides it) long long; float and double, and again if the platform
provides it long double too. However the propertyViewer does (and
should continue to) take advantage of the C++ type promotion rules to
reduce that list significantly, and it is this set of types (plus the
additional EPICS-defined ones) which IMHO CA should support as network
types.
I.e., we still need a well-defined extensible set of data types and
should continue the discussion how this should be implemented. But: I
would rather like to keep that set-of-types definition completely
independent from CA.
Then how are you going to solve the problem of adding new overloaded
reveal() virtual functions without recompiling CA for every client
application you build?
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- Re: Network Accessable Types Ralph Lange
- RE: Network Accessable Types Jeff Hill
- Re: Network Accessable Types Marty Kraimer
- Re: Network Accessable Types Andrew Johnson
Re: Network Accessable Types Kay-Uwe Kasemir
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
