Benjamin Franksen wrote:
how you would implement this record type if all strings become
read-only once created.
You already answered your question: The string gets regenerated every
time. It's a new string, different from the old one. No destructive
update of the string is necessary to achieve that.
So every time you process the record, you free() the old string buffer
and malloc() at least one new one, if not several as we extend the
string? I don't see how that helps us at all, so I'm probably not
understanding what you meant.
You have a record (a struct) that contains a string field as a data
member. If you say I can't modify the string, and I say I can't move
the record in memory, how do I change the value of that string field?
The current EPICS code only allocates memory for database storage at
dbLoadRecords() and iocInit() time, for a very good reason: continual
allocation and freeing of memory *will* fragment the IOC memory pool
into smaller and smaller chunks (we know that from experience, and take
some special precautions inside iocCore which you may not be aware of).
The vxWorks memory allocator is *particularly* bad when it comes to
fragmentation, but even using a better allocator it's not going to be
possible to run an IOC for months or even years without rebooting if
it's continually churning its memory.
Please remember that we have to be able to run on small footprint
systems with 8MB or maybe 16MB of RAM (I think we said 8 at the meeting
last week), and there's no virtual memory so no swapping or paging
possible on these small IOCs.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- Re: Standard String Benjamin Franksen
- FW: Standard String Jeff Hill
- Re: Standard String Kay-Uwe Kasemir
- Re: Standard String Andrew Johnson
Re: Type descriptor vs. enum Benjamin Franksen
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
