2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Standard String
To: EPICS Core Talk <[email protected]>
Date: Wed, 20 Jul 2005 11:11:49 -0500
Kay-Uwe Kasemir wrote:
How would you prefer to handle these?
a) equip the EpicsString class with all the methods
   to change/insert/delete character sequences at any
   position in the string
b) have a
      char buf[...]
   where you can to all the character fiddling,
   then attach a string interface to that in order
   to hand it to the CA Server or other EPICS entity?
   So this String class would actually be non-mutable,
   it only provides read-access to the user-owned buf.
I would prefer b, so we have another example for
my case that the most important task of the string class
it to interface with char *.
c) Design the string class so that it has an internal API giving access to the raw data buffer. Provide a set of manipulator functions that use this API to perform the string operations that we need. Permit anyone else to write additional manipulators for operations they need which we haven't implemented.
We could do that without giving everyone direct access to the raw data by requiring the manipulators to implement a particular interface and then pass a manipulator to the string itself to call, so only the manipulator gets priviledged access to the buffer.
The EpicsBuffer API that Marty and I designed might be a good starting point for the design of the internal API.
...segmented string requirement ... CA network input buffer, without having to copy the character data at all
You're right that the string might arrive in pieces.
Just like the bytes of a double could be wrapped around
the network buffer boundary.
For a double, we expect CA to assemble the pieces back together
and hand us a usable number.
For the string, the end user also most likely needs the whole string.
A double is a fixed size, will always fit into a platform-native type, and is easy to copy around. A string is not a fixed size, will not necessarily fit into any platform-native type, and it not necessarily easy to copy around. Note that if you caget "fred.fields" as a string, you'll get back something which will be pretty large and is probably guaranteed to cross at least one network boundary if not several.
Do you leave the assembly of strings, which logically ought to be hidden
in the network/middle ware layer, to the user?
Using the Data Access API, the user will be presented with a property catalog which contains a string property that holds the segmented data hot off the wire. The data manipulator that the user passes into that catalog's traverse (or find) method will 99% of the time just copy that string into another string in the user's property catalog. That is the moment when the assembly of the whole string takes place in Jeff's design, assuming the user's string is stored in a contiguous buffer; if not, it may have to copy it from one set of segments to a different set. Our EpicsBuffer::expose() methods were designed for doing exactly that kind of copying in an efficient manner.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: Standard String Benjamin Franksen
FW: Standard String Jeff Hill
Re: FW: Standard String Benjamin Franksen
Re: Standard String Kay-Uwe Kasemir
Re: Standard String Andrew Johnson
Prev: RE: Type descriptor vs. enum Liyu, Andrei
Next: RE: Network Accessable Types Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Standard String Kay-Uwe Kasemir
Next: Re: Standard String Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
