I've been thinking about this issue, and I still believe the client
needs to be able to understand any data type that a server can make
available.
Kay-Uwe Kasemir wrote:
Hi:
Where are we with the type enum?
Before the APS meeting,
Ben & Ralph had suggested a type descriptor
similar to what John Sinclair and I
implemented for EDM:
typedef struct
// Character of this PV
enum { real, integer, enumerated, text, special } type;
// real ... enumerated: bit size
// text : max length, 0 for variable length
// special : no clue
size_t size;
// Human-readable description. Currently supported:
// "integer:32"
// "real:64" for double
// "enumerated:16"
// "text:0"
const char *description;
} Type;
... with added info for structs and arrays.
At the APS meeting, Marty presented a simple enum:
int16
int32
uint16
uint32
array
struct
... which would require additional calls in case you find
an array or struct.
He recently tried to nail the contents down,
when Ben raised concerns which I didn't fully understand.
Now what?
Kay
I also think clients will be written in Java going forward, but
nonetheless here's some C++ and general OO ideas.
First, apart from the enum, I think we need a class to describe a data
type and another to describe an instance. How about the following:
enum EpicsDataType
EDT_UNKNOWN = 0,
EDT_BOOL = 1,
EDT_OCTET = 2,
EDT_INT16 = 3,
EDT_INT32 = 4,
EDT_INT64 = 5,
EDT_FLOAT32 = 6,
EDT_FLOAT64 = 7,
EDT_STRING = 8,
EDT_TIME = 9,
EDT_USERDEF = 10,
In particular, arrays are not included. The class to describe types
could look like this (those who believe the STL is unusable can
substitute their own container class for vector). The second class
describes an instance of a specific type, but not the space associated
with it:
* Defines the type, size and contents of
* an EPICS data element. It describes a
* type, not an instance.
class EpicsSymbolDef
public:
bool isArray(); // for convenience
bool isVector(); // for convenience
bool isScalar(); // for convenience
int getNumDims();
string getDataTypeName(); // not always required; a type
name.
EpicsDataType getDataType();
unsigned int getArraySize( unsigned int dimension);
// get array size of given array dimension
protected:
void setDataType( EpicsDataType thisType);
void setArrayDimSize( unsigned int dimension, unsigned int
size);
private:
EpicsDataType _type; /* type of this element */
string _dataTypeName; /* optional name of this data
type */
vector<unsigned int> _dims; /* a size for each array
dimension */
* Describes an instance of an EPICS data
* element. It is an EpicsSymbolDef with
* a specific instance name. It does not
* have storage associated with it.
* Derived classes allocate space and have
* storage accessor methods to manage the
* actual data.
class EpicsSymbol : public EpicsSymbolDef
public:
string getName();
protected:
* can only be created by a derived class instance.
EpicsSymbol( const char *name, const EpicsDataType type);
~EpicsSymbol();
private:
* each instance has a name
string _name; /* name of this element */
and finally, each instance would be described in a generic way to
include actual data. Here's a minimal example, and one could imagine a
lot of accessor methods here, including a constructor to fully describe
the type to the inherited constructor (I'm not sure I've got the syntax
right here, but a typedef for each of the enums at the top of this
message would be used to get a specific instance, like 'class
EpicsData<Int16> x;' or similar):
template<class T>
class EpicsData : public EpicsSymbol
public: // missing a copy constructor, and most other
useful methods!
T& operator[]( int src);
T& operator=( const T& src);
protected:
private:
<T> *_data;
Also, the user defined (struct) kind of record would need a container of
Symbols, so this isn't really complete in that respect.
I would assume an Epics record definition would then be a container for
the types of these epics values and their properties and
sub-properties... (pardon the scarcity of usable methods here!), as
would the representation of a View. Only the data types are described
here, although an instance of such an object could also be used to
contain actual data, since EpicsSymbol is a base class for
EpicsData<Int16> for example, which can contain actual data.
class EpicsRecordDef
public:
protected:
private:
string _recordName;
vector<EpicsSymbol> _fields;
This would allow a client to understand the data definitions, as well as
give it a scheme to store actual data in a type safe way.
I just realized there's a bit much here for an e-mail message, perhaps I
could post this to the wiki.
-doug
- Re: Type descriptor vs. enum Marty Kraimer
- Type descriptor vs. enum Kay-Uwe Kasemir
RE: Type descriptor vs. enum Dalesio, Leo `Bob`
<2005>
<2005>
