2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: [Fwd: RE: Standard String]
To: "'Kay-Uwe Kasemir'" <[email protected]>, "'EPICS Core Talk'" <[email protected]>
Date: Mon, 18 Jul 2005 09:07:43 -0600
The problem is worse than that. The c_str function does not allow an
implementation that is stored in non-contiguous fixed sized blocks (or else
c_str calls malloc, or else c_str isn't thread safe, ...).
Jeff
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Monday, July 18, 2005 8:31 AM
> To: EPICS Core Talk
> Subject: Re: [Fwd: RE: Standard String]
> Hi:
> Jeff wrote:
> > 2) I'm not terribly fond of interfaces that hand off handles to
> > internal
> > data. I'm not enamored, for example, with "std::string::c_str()" and
> > "EpicsString::expose".
> In principle, I agree that c_str violates everything you learn
> about using interfaces and hiding the internal data.
> In fully OO languages like Java where a string constant "blah" is
> interchangeable with a String class and all library functions understand
> this, we'd be fine.
> In reality, however, I'm afraid that many C and C++ APIs still require
> text as (const char *), so whatever String class we use needs to
> convert to/from char * as efficiently as possible,
> and c_str does that for 'reading' the String.
> So just like std::string and MFC::CString and probably most of the other
> C++ string classes, I doubt you can avoid char *.
> -Kay
Re: [Fwd: RE: Standard String] Kay-Uwe Kasemir
Prev: Re: [Fwd: RE: Standard String] Kay-Uwe Kasemir
Next: Re: [Fwd: RE: Standard String] Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
