Marty Kraimer wrote:
At this week's meeting I think we agreed, except perhaps Jeff, that we
want to define a set of well defined types for network accessable data.
These types are used as follows:
1) Data that is meant to be network accessable should be composed of
network accessable data types
2) A client should be able to discover the network accessable data types
of the server's data.
epicsTypes was an attempt by Andrew and I to define such a set. Perhaps
using epics in that name made it seem to be a lot more than just network
accessable data types. The following is a proposed definition for the
well defined network accessable types that is an extension of what
epicsTypes defines. The main changes are:
1) nad (network accessable data) is used instead of epics.
Is this a good name?
If not what is a better name?
netTypeXxxx might be more transparent. Nobody will guess that 'nad' has
something to do with the network.
2) It adds
a) unsigned types
b) property catalog
c) time stamp
d) map
The set of well defined types is:
enum NadType {
nadTypeUnknown,
nadTypeBoolean, nadTypeOctet,
nadTypeInt16,
nadTypeUInt16,
nadTypeInt32,
nadTypeUInt32,
nadTypeInt64,
nadTypeUInt64,
nadTypeFloat32,
nadTypeFloat64,
nadTypeString,
nadTypeArray,
nadTypeMDArray,
nadTypePropertyCatalog,
// Following are usefull common types
nadTypeTimeStamp,
nadTypeEnum,
nadTypeMap
Note that a char type is NOT defined because it is extremely difficult
or impossible to define a network accessable char data type.
Let me briefly describe these types
nadTypeUnknown - This is reserved for the case where the type is not
known. Well behaved sources of data will not present such data.
nadTypeBoolean - This will have the values false and true and is not
meant to be converted to any other nadType
nadTypeOctet - This is an 8 bit byte. It is NOT a numeric data type and
is not automatically converted to any other type
nadTypeInt16,...,nadTypeFloat64 - Primitive data types. The unsigned
types should not be used unless absolutely necessarry. An implementation
can convert between these types using the rules of the language being
used. Thus C++ uses it's conversion rules, Java uses it's rules, etc.
nadTypeString - A UTF-8 encoded character string..
nadTypeArray - An array. The elements of the array can be any of the
nadTypes except nadTypeUnknown.
nadTypeMDArray - A multidimensional array.
What types are alowed?
Perhaps only nadTypeOctet,...nadTypeFloat64?
nadTypePropertyCatalog - Is this the correct name or should it be
Struct? Using PropertyCatalog implys that we are agreeing the dataAccess
is the way data is transfered between network accessable components.
nadTypeTimeStamp - This is a "convience" type. It is provided because it
is so widely used.
nadTypeEnum - Again this is a convience type.
nadTypeMap - Convience type. If available, it will be widely used.
If these types are acceptable, then it will still be necessary to agree
about the details of each type.
Marty
Is there such a thing among these types as a counted string? I mean a
string whose declared length may be larger than the number of significant
characters, but which cannot be null-terminated because it may contain
nulls (e.g., as part of a checksum).
Tim Mooney ([email protected]) (630)963-1860
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- Network Accessable Types Marty Kraimer
Re: Network Accessable Types Kay-Uwe Kasemir
<2005>
<2005>
