2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Record support and user-defined fields
To: [email protected]
Date: Mon, 11 Jul 2005 21:50:04 +0200
On Monday 11 July 2005 14:55, Marty Kraimer wrote:
> Also templates should not appear in the DBD files. This can be done
> by properly defining interfaces which are implemented by "record
> fragment".
Hmm. Can you explain how, for instance, an 'invalidOutput' struct can be
specified in the DBD so that it is usable as building block for
stringout as well as ao record type, without parameterizing over the
type of the value?
> There should not be ANY language specific definitions in DBD or DB
> files.
Note, in my original proposal (on the wiki), there is not a single
mentioning of a C or C++ language feature in the DBD file. If you
insist, I can write down a precise and self-contained definition of the
meaning of the angle-brackets notation I used in the DBD fragments I
posted.
Ben
Re: Record support and user-defined fields Marty Kraimer
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Andrew Johnson
Prev: Re: Record support and user-defined fields Marty Kraimer
Next: Re: Record support and user-defined fields Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
