Andrew Johnson wrote:
I like Ben's idea of introducing type parameters into the DBD file,
but I want to make some changes to his struct support. I'd like to
distinguish between a struct (which should only contain plain data)
and a class (which also has methods that have to be implemented in C++
code). It would obviously save effort if we only have to write the
alarm limits checking code once as a template, which can then be
instanciated for all types as needed, and this starts to break up a
record into smaller modules that have a defined functionality. The
parent record type code would still be responsible for connecting all
of the modules together into a cohesive whole record.
I think the DBD files should only define structs, i.e. only describe data.
I do not see why implementing "record fragment" support like alarm
checking requires class definitions in DBD files. The only thing that
should appear in the DBD file is the struct containing the data.
Also templates should not appear in the DBD files. This can be done by
properly defining interfaces which are implemented by "record fragment".
There should not be ANY language specific definitions in DBD or DB files.
I also wonder how much C++ STL we should allow into record support.
Marty
- Re: Record support and user-defined fields Benjamin Franksen
- V4 iocRecord: forward linking Ralph Lange
- Re: Record support and user-defined fields Kay-Uwe Kasemir
- Re: Record support and user-defined fields Andrew Johnson
Re: V4 EpicsString Benjamin Franksen
<2005>
<2005>
