2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Record support and user-defined fields
To: [email protected]
Date: Thu, 7 Jul 2005 23:44:16 +0200
On Thursday 07 July 2005 21:28, Andrew Johnson wrote:
> By "export the result" above, I mean make it available through CA as
> another named view of the record it applies to.  Thus if we provided
> a general-purpose "maximum" filter you could connect it to say the
> value view of your record "fred" and it would then make the running
> maximum of "fred.value" available as a "fred.max" (or whatever you
> named your new maximum filtered view).  The maximum calculation would
> be performed by the filter every time the record posts a new value to
> the underlying view.
> The record has no knowledge of the presence of the filter, it doesn't
> have to call any hook routines, and the field view doesn't have to
> know anything about an extra field, since this isn't one at all.
> This exact same approach can be used to implement the circular buffer
> logging facility, and using views this could permit clients to
> specify parameters to the view - say "give me the history data for
> just the last 10 seconds."
I like this idea very much. Take such things away from the record
(type/support) and put it into other independent things. Views are
better such things than additional records, since the connection
between the view and the original record is more obvious to clients.
So, another way to look at the concept of 'view' is to visualize it as
an additional record, that is not visible as such, but instead makes
itself seen (from the outside) as additional 'fields' (rather:
properties) of a record.
> > Actually, I don't use the FLNK, HIGH, SIML, ... fields in most
> > records, so could they all go and only be added as required?
> That's a rather different requirement, the problem is how you would
> connect all the little pieces together and execute them at the right
> time.  I'd like to find some way of making records out of smaller
> objects, but I don't think we're anywhere near that yet.
What I proposed for the IVOA/IVOV example is easily adapted to other
scenarios, like simulation stuff, or alarm limit handling. Ok, all this
needs a developer who writes the code and (more importantly) designs an
appropriate interface that is general enough to be used in any record
type that needs such a facility.
OTOH, it would of course be great if we could assemble all these pieces
at record load time, rather than compile it into the record type, so
that each record will only have what it really uses. I just can't see
how to do this in a manner that is at the same time efficient and safe.
Well, apart from developing yet another programming language for the
task.
Ben
Re: Record support and user-defined fields Andrew Johnson
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Kay-Uwe Kasemir
Prev: Re: Record support and user-defined fields Andrew Johnson
Next: Re: Record support and user-defined fields Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
