2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Record support and user-defined fields
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Thu, 07 Jul 2005 14:28:54 -0500
Kay-Uwe Kasemir wrote:
Things I had in mind:
- Add a 'maximum' or 'average' to some ai, ao, calc, subroutine, ...
  record instances
> - Make a record post all/some values to a logging facility
>   or circular buffer
Ok, these are the filters I was talking about - the ability to take a posted value, apply some additional processing and export the result.
- Add a(n additional) forward link to a record
If we take Ralph's (IIRC) suggestion that the FLNK field be an array of links, you wouldn't need this. I'm not totally convinced about that yet, but it's one solution; another would be to just use a fanout record which is exactly what it was designed for...
In case of the max., average, ..., I think it would be really nice
to have this as a field of the record. How else would I access
the current maximum? I'd like to access it via CA, see it in dbpr, ...
By "export the result" above, I mean make it available through CA as another named view of the record it applies to. Thus if we provided a general-purpose "maximum" filter you could connect it to say the value view of your record "fred" and it would then make the running maximum of "fred.value" available as a "fred.max" (or whatever you named your new maximum filtered view). The maximum calculation would be performed by the filter every time the record posts a new value to the underlying view.
The record has no knowledge of the presence of the filter, it doesn't have to call any hook routines, and the field view doesn't have to know anything about an extra field, since this isn't one at all. This exact same approach can be used to implement the circular buffer logging facility, and using views this could permit clients to specify parameters to the view - say "give me the history data for just the last 10 seconds."
Actually, I don't use the FLNK, HIGH, SIML, ... fields in most records,
so could they all go and only be added as required?
That's a rather different requirement, the problem is how you would connect all the little pieces together and execute them at the right time. I'd like to find some way of making records out of smaller objects, but I don't think we're anywhere near that yet.
If I can suggest an alternate approach that could provide this functionality but doesn't involve "adding a field at runtime", would you accept this instead?
Absopositively. What do you suggest?
Does the above describe an acceptable alternative?
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: Record support and user-defined fields Benjamin Franksen
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Kay-Uwe Kasemir
Re: Record support and user-defined fields Andrew Johnson
Prev: Re: Record support and user-defined fields Kay-Uwe Kasemir
Next: Re: Record support and user-defined fields Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
