Hi:
Thanks to Jeff for adding the number.
~60000 lookups (or is it connections?) per second for CA
sure beats the OpenLDAP number of only 1500 lookups/sec
to pulp.
What's harder to measure/test/compare:
When I start a new EDM screen, it connects quickly,
which I guess is because of the 60000/sec.
But when I reboot all ~40 SCL LLRF IOCs,
the screen will often not reconnect for a minute.
Is that because of SNS network misconfiguration?
Is the concept of detecting changes in beacon timing
too tricky, and a straight directory lookup
of where a PV is supposed to be would be quicker?
-Kay
On Jul 6, 2005, at 17:39, Jeff Hill wrote:
All,
I added the attached text to Kay's name resolution discussion (on the
wiki).
Jeff
JOH: For comparison purposes, here is the performance of CA's built-in
name
resolution.
Testing with 100000 channels named joh:bill
channel connect test
Elapsed Per Item = 0.00001683 sec, 59427.3 Items per sec, 31.4
Mbps
Search tries per chan - mean=1.000930 std dev=0.030482 min=1.000000
max=2.000000
- RE: name resolution performance Jeff Hill
- name resolution performance Jeff Hill
Re: Agenda for next week Benjamin Franksen
Re: Record support and user-defined fields Andrew Johnson
<2005>
<2005>
