2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Record support and user-defined fields
To: [email protected]
Date: Wed, 6 Jul 2005 23:32:23 +0200
On Wednesday 06 July 2005 16:01, Kay-Uwe Kasemir wrote:
> Thanks for your comments, I think I got them all added
> to the user-defined-fields page.
> The whole point is to get the pros & cons collected,
> so that we can then decide what we need and in what order.
Yes.
> I see good reasons for both adding fields to record instances
> (easy to use, but limited functionality)
> and having building blocks for new records
> (requires more forethought but also more options).
Yes, I agree. I think both aproaches are possible and maybe we should
have both available.
> For example, the current AI, AO, CALC, CALCOUT, SUB, DFANOUT
> records all have very much the same code for handling the
> alarms via LOLO, ..., HIHI, LLSV, ..., HHSV.
> The necessary rewrite of the database for V4
> would benefit from only having to write that once
> and then build those records by invoking the same 'analogAlarms'
> code.
Yes. And new record types would be easier to write, too. And behavior
would automatically be more uniform & predictable. This is true
regardless of which of the two methods is chosen.
Ben
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Benjamin Franksen
Re: Record support and user-defined fields Kay-Uwe Kasemir
Prev: RE: Agenda for next week Dalesio, Leo `Bob`
Next: name resolution performance Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Record support and user-defined fields Kay-Uwe Kasemir
Next: Re: Record support and user-defined fields Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
