2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Record support and user-defined fields
To: Kay-Uwe Kasemir <[email protected]>, [email protected]
Date: Fri, 1 Jul 2005 02:37:20 +0200
Hi Kay,
I hope you don't mind I post this on the list.
On Thursday 30 June 2005 17:47, you wrote:
> On Jun 30, 2005, at 07:35, Benjamin Franksen wrote:
> > I don't yet see how we specify when 'user-defined fields' get
> > processed.
> My proposal allows them to hook into the record's processing
> at two points:
> After getting the value (so the hook can modify the data),
> and at the very end (so the hook can add averaging or FLNKs or ...).
> That handles all the test cases which we had at the SLAC meeting.
Ok, two seems to be a rather modest list. Anyway:
o what if there is no 'value' (see a recent posting on core-talk, I
believe it was from Andrew)
o what does smoothing do if the value exists but is an array. Or an
integral type. Or a string?
> > Thus, I argue for abandoning the idea to have per-instance defined
> > fields. Instead, ..... create a new record type.
> Sounds great. Can you create a wiki page with more detail
> as to how the dbd & db file would look as well as the API
> for the process()-pieces that each record-snipped needs to provide?
In a nutshell: dbd changes: none (I'll leave type variables out for the
moment); API: depends on the function block/struct; DA implementation:
exactly as for the 'fields' view for records. I'll try to present an
example on the wiki.
Ben
Re: Record support and user-defined fields Kay-Uwe Kasemir
V4 iocRecord: forward linking Ralph Lange
Record support and user-defined fields Benjamin Franksen
Prev: Re: dataAccess V4 primitive types Benjamin Franksen
Next: Re: Record support and user-defined fields Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Record support and user-defined fields Benjamin Franksen
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
