I am going back to a statement that started this entire discussion. It
may not have been stated exactly as follows but it is:
"A well defined set of basic types should be defined. The basic types
can be divided into primitive (octet, int16,...,float64) and aggregate
(string array, struct) types. Other well defined types can also be
defined such as timedStamp, enum,etc."
Again the reason for defining a well defined set of basic types is so
that network applications can easily share data.
Since the data is meant to be shared by applications running on
multiple architectures and written in multiple languages, it is
important that the basic data types be well defined.
type_info should be defined so that all the basic types can be
identified.
dataAccess should adapt the set of basic types instead of using the C++
primitive types (char,short,etc).
The epicsTypes.wiki is an attempt to define such a set. It lacks a way
to define hierarchies and a way to associate array element types with
basic types but if these are defined than perhaps it is the basis for
the set of network accessible basic data types.
If dataAccess adapts these basic types then perhaps a way to define
type_info is via propertyIds, e.g.
propertyId propertyTypeOctet ("epicsTypeOctet");
propertyId propertyTypeInt16("epicsTypeInt16");
The set of basic types should also describes the set of basic types for
the network protocal, which requires a 1-1 mapping between the
type_info and the type id used in network packets.
Marty
On Jun 30, 2005, at 7:00 AM, Ralph Lange wrote:
Marty Kraimer wrote:
I suspect, however, that specifying how type_info is defined will
lead to lots of debate starting with the definition of primitive
types and then strings and arrays and then structured data.
Benjamin and I didn't want to lose discussion time and decided to go
ahead starting that debate ....
Our idea is to /not/ make that type info a simple fixed enumeration of
fixed types, but use a dynamic structure to describe a type. We came
up with the following:
type = string 1)
| timestamp 2)
| signed (bitwidth) 3)
| unsigned (bitwidth) 3)
| float (float_format)
| struct 4)
| array (base_type, size) 5)
float_format = ieee32 | ieee64 | ieee80
Annotations:
1) String should be a basic atomic type - regardless of its
implementation.
2) For efficiency reasons (as timestamps are shipped around and
handled all the time) the timestamp should be an atomic type that can
easily be mapped and assigned to the EPICS supported C/C++ types.
3) A server or client app can choose any locally available data type
that is appropriate and wide enough to store the data. Future wider
integers are supported. As for signedness, alternatively there could
be one integer type with another parameter giving the integer format:
| integer (int_format, bitwidth)
with
int_format = unsigned |signed
4) This basic type is needed for properties that actually are a
contained list of other properties.
5) base_type is another type_info. If we need a type where arrays do
not start with element zero, size might be replaced by a (min, max)
pair. Multi-dimensional arrays are represented as arrays of arrays.
This type_info has a dynamic size (it's a union - which really seems
to be a natural way to describe lots of things...). Making itself a
property catalog seems a slim and convenient way to interface it.
IOC side ideas:
It is perfectly allright for the IOC Database implementation to use a
fixed enumerated number of fixed types. This may be the most efficient
implementation. When the CA connection is made, the CA server will
have to find out about the types of a property catalog owned by a
record using the type_info to decide which network representation it
uses for the data.
In case of a fixed list of enumerated fixed types, a bunch of static
property catalogs will be enough to fulfill most of these type_info
requests. A plain table can hold the connections between fixed types
and their type_infos. (There's no need to generate a type_info
property catalog for each record instance nor for each record type.)
For menus, the needed bitwidth could be reported correctly to the CA
server, as the number of choices is fixed at compile time. This would
allow CA and the client side to optimize storage - independent from
the implementation in the IOC Database.
Possible DBD look-and-feel:
Wouldn't have to change. If the Database is implemented using
predefined fixed types, everything stays the same. Otherwise, the
parametrized types would be used instead of the fixed ones, i.e.
int32 would become signed(32)
float64 would become float(ieee64)
and so on.
So much for the first iteration....
Benjamin and Ralph
- dataAccess V4 Ca client propertyId questions Marty Kraimer
- Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
- Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
- Re: dataAccess V4 Ca client propertyId questions Ralph Lange
- Re: dataAccess V4 primitive types Ralph Lange
Re: dataAccess V4 primitive types Andrew Johnson
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
