Benjamin Franksen wrote:
On Tuesday 28 June 2005 16:42, Andrew Johnson wrote:
What does a "Backward" link really mean, how do you implement it,
No, I meant a normal input link! You can make it CPP or CP, of course,
like any input link. Very simple.
"Backward link" is just my name for your input link; I don't want any
common feature like this to only work with CA links (there should be
nothing special about CA links in V4, they'll be just another kind of
link support). Your "very simple" implementation idea is guaranteed to
only work with CA links that are CP/CPP, and I don't like that at all.
To support it for DB links, we'd have to add all the stuff I talked
about since we don't yet have change event notification on input DB links.
I really don't want us to add "Backward links" to EPICS; we should fix
the event scan as the solution to your original issue.
That does bring up the point that there is a significant difference in a
CA link that is CP/CPP than most other kinds of link: the "process me on
change event" behaviour is unique for an input link, and we should think
about whether we could have a standard way to support that for other
link types. There is something conceptually very similar about it to
I/O interrupt scanning from an input device support -- could we create a
single mechanism that implements both? Maybe remove I/O Interrupt from
the list of scan types even...
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- More flexible record scanning Benjamin Franksen
- Re: More flexible record scanning Benjamin Franksen
- Re: More flexible record scanning Andrew Johnson
Re: V4 iocRecord: forward linking Kay-Uwe Kasemir
Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
<2005>
Re: Version 4 EPICS Ralph Lange
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
