The current FLNK implementation in V3 (and also what's on the wiki for
V4) is a single link field.
My experience is that in most cases you either don't need an FLNK or you
actually need multiple FLNKs (usual workaround is linking the targets in
a chain through their respective FLNKs or using a fanoutRecord).
In other words: the implementation matches exactly the least common
situation. Not good.
Suggestion:
For V4, make FLNK an array of links with a default size of zero.
This uses less space in the most common case, allows for very flexible
FLNKing, and it eliminates the need for a fanoutRecord.
Ralph
- Re: V4 iocRecord: forward linking Kay-Uwe Kasemir
Re: More flexible record scanning Benjamin Franksen
Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
<2005>
ANL Gate Passes Andrew Johnson
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
