Benjamin Franksen wrote:
Event scanning using raw numbers is much too fragile.
That I accept; in V4 we should consider changing the EVNT field to
become something like a string or better yet, an extensible menu (I've
just added a note about such a requirement to the DBD Statement Syntax
wiki page on menu definitions).
In contrast, an input link for the PROC field never accidentally 'leaks'
to the outside, at least if the 'scanning' record instance is part of
the same database file.
What does a "Backward" link really mean, how do you implement it, and is
it really worth the overhead (which would be more than just one
additional link in every record)? For CA links the meaning is probably
relatively clear: "process me whenever you get an event from that
channel", and the CA client library already provides the necessary
infrastructure. However to implement it for a DB link we would have to:
* Add the "Backward" link to dbCommon
* Add a linked list to dbCommon, containing pointers to all the other
records that have a "Backward" link to this record
* When initializing the database, construct the linked lists for all records
* After (or before?) processing the FLNK of a record, also scan that
linked list and process all the records on it
* Perform special handling for "Backward" links whenever they get
changed, deleting the link owner from its target's old list and adding
it to the new target's list (this processins requirement is unique, we
never have to do anything like it for any other link fields)
IMHO this is unnecessary, and adding it would be using a sledgehammer to
crack a nut (as would using an empty tagged union to implement enum/menu).
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- Re: More flexible record scanning Benjamin Franksen
- More flexible record scanning Benjamin Franksen
- Re: More flexible record scanning Andrew Johnson
Re: dataAccess V4 Ca client propertyId questions Ralph Lange
ANL Gate Passes Andrew Johnson
<2005>
<2005>
